Atari 1 System Issue
ricotalbot
1CR
Have you guy's ever seen this issue on an Atari 1 System, it's like the words are scrambled and I can't make out the error. Any Ideas to where to look
ricotalbot
1CR
It’s when the cartridge is in, if I remove it it does come up with the default no cartridge but this also has scrambled letters so I’m guessing it’s the main PCB? Just to sure where to start, where is the screen ram on these?
GadgetFreak
881CR
Tip: Even with bad screen ram it should still work but you may have to just look for a colour change on a particular line and then check with the display posted in the thread to see which chip.
ricotalbot
1CR
Hey guy's thanks, I was just checking the voltage out of my original System 1 power supply, there are 5 fuses in this bank and 1 of the 5 I don't get anything and the fuses I have checked, does someone have the layout of what voltage I should be getting from all of the 5, there is also a main one and this is fine.
Maybe this is just a voltage problem that is causing this scrambled screen. Thanks as always.
