Cool beni thanksHi mate, I’ve got a Neo 25 with Hitachi tube, I’ll check what yoke it has. Believe it’s the Toei chassis
Yeh …I’m not so sure. I think this is just the reality of using the original Toei yoke as it seems others had the same symptoms when trying this.
You able to identify those caps? I’ll swap them out if so but I’m hopeless at diagnostics as you can tell!Yeh …
Or could it be bad pin cusion?
Bad cap in that local would
Cause that symptom.
Did others have bad pin ?
Or bad horizontal width ?
I’ll get these readings. I need to get a meter to measure inductanceyou really could do with the inductance and impedance readings of the yoke
