That's a lot of soldering to go through. Can whoever you get to produce the PCBs, provide a socket soldering service? At least all those pins would be pre done and only needing the I.C.s to be pushed in.
Infurious said:That's a lot of soldering to go through. Can whoever you get to produce the PCBs, provide a socket soldering service? At least all those pins would be pre done and only needing the I.C.s to be pushed in.
bobmoo79 said:Fantastic. Looking forward to future updates!!
Martinmurphy30 said:Amazing work, I'm not familiar with the Mr do PCB but what does it use for colour proms? And you mentioned alterative colour sets? So I'm guessing fast enough eeproms with the different colour ROMs selectable? I've created a small daughter board to replace the colour proms on a choplifter bootleg (or original) to replace the original proms with eeproms which you could easily make a miltiboard from. Again fantastic stuff!
Martinmurphy30 said:When you get this working I'd definitely be interested in buying one to assemble! Please keep posting! Great stuff!
Crazy amount of soldering. Even for one board I'd be wanting a solder flow tank, lol.Now we are back and running on the new Ukvac, I can update on recent progress with the mr do clone!!
Originally I was trying to assemble different sections of the video section to test independently ie bgnd foreground, sprites etc but I just wasn't getting any stable picture. So I decided to assemble some other parts as well. Here is the progress
This got me to this stable screen.
Game doesn't run yet , but to see some decent clear video output was a good milestone and also proves a lot of design sections. Next to work out why the game code doesn't run.
I also populated the reset of the sprite section to see what the garbage screens looked like to compare with an original board etc.
This is what I get now on first power on. Not the same yet but is encouraging.
More to come![]()
I’ve consolidated as much as possible and checked all parts are still readily available. I've also made a few changes so there's less overall part differences. I’d like to reduce the parts count alittle more to, but need to get it running in this form first. I have designed a few pal chips to in the game section and that's what i need to check next.I completely missed all this.
Awesome project! Looks FINE as hell in purple too. I wonder how much all the parts would be to buy in the end?
