MW RT-85A PSU issue
penrhos
23 (100%)
747CR
Hi All,
I've got a problem with a replacement PSU for one of my super gun's.
I've got a Meanwell RT-85A and it keeps pulsing off and on when there's no load on it so I can't get it setup.
According to my google-fu it's because there isn't enough load on the 5V line and it needs about 20% load to stop it shutting down.
So 20% of 8A is 1.6A so If I calculate for 1A or 2A...
My maths is a bit rusty but.
Ohms law - R = V / I
R = 5V/1.0A or R = 5V/2.0A​
R = 5 ohms or 2.5 ohms.
Watts Law - P = I * V
W = 1.0A * 5V or 2.0 * 5V​
W = 5 or 10.
So am I correct that I either need a 5 Ohm 5W resistor or a 2.5 Ohm 10W resistor depending on if I go under or over the 20% minimum load on the 8A +5V rail?
7,438CR
So even with a pcb inserted ( load )
It don’t stay on?
Just found this on Aussie arcade
“Some of my Mean Well power supplies have a minimum load of 1 Amp on the +5V line and Neo boards don't even pull that much, meaning the PSU doesn't activate. Thankfully Mean Well have removed this restriction in their latest design.”
penrhos
23 (100%)
747CR
Success - found a 10 Ohm 3W ceramic in the bits box - popped it across GND & +5V and she's up and stable with or without any load on the Edge connector...
So if V/R = A then I only needed 0.5A of load to trick the protection circuit. and 0.5A x 5V = 2.5W - so what I found will do so it's a free fix!
