Solved Neo-Geo 4 Slot no sprites
1,786CR
Hello,
Here I have this 4 lot neo-geo with no sprites. I don't have mucx experience mith neo-geo so I don't know where to start. I patched some NEO-253 on the top board and it brought sound and fixed layer back to life. I have activity on other neo-253 that are used for sprites. unibios and diagnostrics bios show no ram error.
I can't probe much on the bottom board becouse of the top board and without top board it won't make much sense, right?
Could the NEO-ZMC2 be faulty here?
Thanks a lot.
7,319CR
Yeah I want to probe z80 and Yamaha sound chip but I guess
It won’t be functioning fully without top board and cart running ,
Being a two board sandwich don’t help much does it !
7,319CR
I have a board with a bad
Games play no sprites…
I did have jail bar sprites ..
Tried to reflow the chip
Neo zmc2. F****led it
I still need to suck some solder out from under the chip that’s bridging legs ..
Since then same symptoms as yours ..
So maybe a bad ic or cold solder but yeh worth at look at that one
7,319CR
Point taken..👍
Received it faulty
I have junk to work on and I intend to …
Temptation to reflow got the better of me ,
Chip was showing jail bars when I got it
38 (100%)
3,816CR
I'm not trying to be mean, we all started out like this. That custom chip could be saved with a lot of time and work, but it was years before I was comfortable working on surface mount stuff.
The right tools, watching some youtube videos and some practice will go a long way, not sure what iron you're using but a temp controlled one and a few different tips would help a lot too.
