Solved Taito 3 layer pcb roms?
Ronnie Dent
1,205CR
Hi looking for some advice? Been checking over this board and and the legs are falling of the roms ! Looks like new roms and sockets needed! But there are 10 of them on 2708’s what other roms can be used? I have 2732’s , downloaded the romset but looks to be just 5 files so I’m a bit stuck!
Thanks Ronnie
Ronnie Dent
1,205CR
Thankyou so looks I need 2716 x5 there are jumpers and I see info on setting them for 2716 looks like each one has a jumper. Also need to check my programmer does these
bones
1,628CR
I did manage to program a 2716 for a field goal on a tl866 programmer by bending the 21v pin out of the socket and connecting a separate power supply to it(old battery hoover psu, just cut the plug off lol). I loaded everything up on the computer ready to burn and only turned the 21v psu on just before I hit the burn button. I did link the 0v together though, I think as long as the 21v leg is not in the programmers socket it's ok.
Ronnie Dent
1,205CR
2732 is in the device list on my Wellon VP-280 and it has it's own psu but sure it puts out 21v
@Georgian2
Also on the board pin21 is not connected to the 5v rail so should be ok without doubling up the file@
1,869CR
@Georgian2
Depends if its 5V or GND. If ist 5V you need to double the file since only the upper half will be used. If it's GND, no need to do it since only the lower part will be used. If floting, conect it to gnd and just burn the 2716 file to an 2732. Don't leave it floating.
Ronnie Dent
1,205CR
Thanks for that I will check.
So I don't know how to get the files doubled in the buffer! I can load it once but must maybe need doubled before adding somehow?
Thanks Ronnie
40 (100%)
3,990CR
You can use binman here to double the files before you open them in the programmer.
or use a dos prompt and use the command copy /b file.name + file.name new.file
Ronnie Dent
1,205CR
Thanks Ace, I'm hopeless with this stuff! And most stuff TBH! Would you be kind enough to do this for me:unsure: I will tie myself in knots!
  • invadpt2.zip
Ronnie Dent
1,205CR
managed to get the roms done, thanks guys! At first power on I realised I put the shifter chip in the wrong way mb14241 after repairing some broken legs so that got very hot and no doubt is toast! Anyway the screen is not right either but I got some sort of blocks on the screen and not much else happening I might need to get the board looked at, no idea who still does this? The psu is fine I checked all the voltages prior, had to replace a 5v regulator and a diode, been over the strapping and I’m confident it’s all correct
bones
1,628CR
Can't remember where you can get it but there is a test rom for this space invaders boardset, I have used it in the past, maybe someone can give you a link ?
