geotrig
<_>
103CR
god this thread ,why wont it die yet. a tube is just that a vacumn tube nothing else really. i think you are over complicating this in your head. the rest is complex circuits and connections.
geotrig
<_>
103CR
and just to add a basic ai answer as i think this is where you are coming from ?
For basic cathode ray tube experiments, a voltage as low as 50 volts can be sufficient to produce a visible electron beam. However, higher voltages, often in the range of 300-400 volts, are commonly used to obtain a brighter and more stable beam, especially when using tubes designed for low voltage operation. In early experimental tubes like Crookes tubes, thousands of volts were used to ionize the gas and generate cathode rays.
Cathode Ray Tube Experiments – PhysicsOpenLab
Here's a more detailed breakdown:
  • Early Cold-Cathode Tubes (e.g., Crookes Tubes):
    These tubes relied on high voltage (thousands of volts) to ionize the residual gas inside the tube, which then produced electrons that formed the cathode ray.
  • Modern Low-Voltage Tubes:
    Modern designs, especially those using Wehnelt cathodes, can operate at much lower voltages (300-400 volts) while still producing a visible electron beam.
  • Factors Affecting Voltage:
    The required voltage depends on the specific tube design, the desired beam intensity, and whether the experiment involves other factors like deflection or fluorescence.
  • Voltage and Beam Properties:
    Higher voltages can lead to a brighter beam and potentially better resolution in applications like oscilloscopes.
  • Safety:
    It's crucial to remember that high voltages can be dangerous. When working with cathode ray tubes, always follow proper safety procedures and guidelines, especially when dealing with voltages above 300-400V.
739CR
Oh, this thread had the answer on page 3 page, @geotrig ...
The CRT Tube is not tied to a specific (110V or 240V) ... :)
I would presume because it's just a place to bounce electrons around or some shit! 😅
However, if if the ongoing discussion is frustrating you, then perhaps it might be good idea for you to utilise the 'ignore' button at the top? If not, I'm sure it's all great additional information, either way. :)
With regard to "over complicating this in your head" ... erm ... I'm not entirely sure that is possible with my tiny brain! 😅 ...
It is why I made the thread as simple as possible ... a yes / no as to whether or not a CRT Tube cares about whether the voltage used with whatever is feeding the CRT Tube is at 110V or 240V ... and the CRT Tube does not care. (y)
So the answer is that CRT Tubes are not tied to a specific voltage (like 110V or 240V). :)
All the shit that plugs into to it can be running at whatever voltage ... the CRT tube isn't bothered.
Essentially:
5,401CR
chatGPT
To estimate the required accelerating voltages (anode voltages) for CRTs across various screen sizes and horizontal scan frequencies (15 kHz, 24 kHz, 31 kHz), we can follow general principles used in CRT design. Anode voltage primarily affects beam focus and brightness and must increase with screen size and resolution.
Here’s a table summarizing the **typical ranges** of kilovolts required for each configuration:
These are **approximate values**, as actual designs vary by manufacturer, tube phosphor type, and intended usage (arcade, TV, professional video monitor, etc.).
As a rule of thumb:
- **Larger tubes** need **higher voltages** to maintain image brightness and sharp focus.
- **Higher frequencies (resolutions)** require **more precise beam control**, often necessitating higher voltages and better deflection circuits.
Want to dive deeper into how these voltages influence image clarity or how arcade and broadcast CRTs were engineered to push performance?
739CR
Will do, @CMYKhazi-Dan !
Put me down for three of these @eliotcole 👍
Only if you promise to fite me at CVS2 on fightcade sometime 😏
Cheers for this, @Alpha1 ... I do not take information from AI, however I will just assume that this backs up the knowledge based responses, earlier, that a CRT Tube does not care about a mains voltage of 110V or 240V ... thanks again for the response. 🙂 (y)
chatGPT
As a rule of thumb:
Rossyra
33CR
Whelp, tubes don’t take the mains supply voltage, the chassis does that and feeds the tube the voltages it requires. So the 110v/240v isn’t relevant to the tube
739CR
Thanks, @Rossyra ! Perfect !
Providing it outputs the right other specs for a given tube, I will slap a 240v chassis on some tube that I have.
Brilliant!
Cheers! :)
