Hello, does anybody have the pinout for this Jaleco peek a boo PCB? 44 pin. Thank you.
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 21, 2025 #1 Hello, does anybody have the pinout for this Jaleco peek a boo PCB? 44 pin. Thank you.
FanDabbyDozy Active member Feedback 22 (100%) Credits 170CR Oct 23, 2025 #2 Not sure how much help this will be, might be able to work out pinout from photos, can try and list pinout if have no joy.
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 23, 2025 #3 FanDabbyDozy said: Not sure how much help this will be, might be able to work out pinout from photos, can try and list pinout if have no joy. View attachment 46782 View attachment 46783 View attachment 46784 View attachment 46785 View attachment 46786 Click to expand... Many Thanks!!!! All I need is power and RGB, after I can trace everything from test menu. Thanks a lot!
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 23, 2025 #4 Yeah...the good old video ram error.
FanDabbyDozy Active member Feedback 22 (100%) Credits 170CR Oct 24, 2025 #5 Glad it helped, hope you get board up and running
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 24, 2025 #6 FanDabbyDozy said: Glad it helped, hope you get board up and running Click to expand... Can you please check if pin 6 and 7 on the ls245 IC33 are shorted on your board? The ic itself is not shorted, the inputs are on my pcb.
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 24, 2025 #7 I managed to hit 2 birds with one stone. I found the short. Reflowing IC51 also resolved the reset problem on the OKI M6295 soud IC. Everything works now. Thanks again!
G Georgian2 Active member Feedback 12 (100%) Credits 1,781CR Oct 24, 2025 #8 Pins for an potentiometer or encoder are still unknown otherwise pinout complete.
