ROM dumping/burning newb woes
5,671CR
Figured it's about time to get to grips with this malarkey, so I've bought a T48 to dip my toes in the water.
First problem I've had is that I get an error trying to read a D27128-3. This is a ROM I pulled from a working board just to test with. I tried another type of EPROM which I managed to read ok.
T48 is USB powered so I tried a different port. I've updated the firmware, also.
Anyone with a T48 know what's up?
Thanks.
Hexen
487CR
Thanks.
A 27128 is about as standard as can be - as long as it's set to read a 128, it should without a problem. Maybe the device is dead?
5,671CR
Yeah, definitely set to read 27128 and the ROM works on the PCB I pulled it from. 🤷‍♂️
Hexen
487CR
Dirty pins on the ZIF side? Sometimes I get errors as the PCB sockets use the sides of the chip pins, the ZIFs use the edges. T'was fun reading a 2708 the other day to copy it. Different checksum every time until the pins were individually cleaned with a scalpel.
I assume there are other Intel 27128s on the board that read OK?
5,671CR
I did try cleaning the pin edges with iso, but maybe they need a scrape. I'll give it a go. No other Intel chips on the board, but there is a Mitsubishi one. I'll see if I can read that. Cheers.
Jacmar
700CR
I generally have it un-ticked yes as otherwise it flags an error if the chip you put in doesn't match perfectly the make and model selected.
5,671CR
That solved it. It was passing pin detect but failing ID check, for some reason. I managed to dump the ROM and check it with RomIdent to check all's good. Thanks!
