Ridge racer 1 /2 Logitech analoge
7,399CR
Any one use Logitech
Xbox 1 wheel for ridge race can share their analoge settings ?
Also chase HQ accelerator is proving a little confusing for my brain ..
So delux type cab and convertion cab is analogue accelerator but standerd cabs are not analoge accelarator.
If anyone uses Logitech with chase hq & csi aka chase hq -2
love to know config set up that works with pedal 👍😊
My controls but only accelorates using one of the buttons ?
yoganuggy
639CR
Ridge Racer:
Open
mame.ini and set the max saturation to 1 (default is .5. .i.e. 50% turn is a full turn) and the deadzone to 0.0. AFAIK the default deadzone is .3 (30 percent!).
Then go into the game service menu F2 and calibrate.
Sci / Chase hq
The pedals and hi/lo gears are simply on off buttons so map your button 1 to gas pedal and button 2 to brake. Sometimes you have to invert the axis if the game detects gas or brake is on when you foot is off and vice versa.
There is something you can do for the hi/low in the game cfg file but I can't remember. Same shifter type in outrun. Google "mame shifter outrun cfg" and it should come up.
And disable those inc dec in your config. Not used when you have a wheel.
7,399CR
Ridge Racer:
Open
Sci / Chase hq
Nice one yoganuggy ..
Gonna try this !
Will let you know how I get on with these settings.
thanks
Sounds very similair to what I was implementimg but using the Logitech hub.
How’s about the in game tab menu / analog controls .
Digital speed , sensitivity ,etc?
Do you change these settings ?
4,770CR
Upright and even my sitdown Chase HQ have switch pedals for accelerator and brake, I'll have to look at the DX Manual and see what that has
Continental Circus uprights have switch pedals too but sitdown has stepped opto for pedals
I've not played Chase HQ on mame that I remember but before buying machine I used to play it on Raine Emulator and it worked awesome on that with Thrustmaster FFB wheel and Pedals
7,399CR
Yeh im looking also for the good emulator for RR if thats still the case ?
Or is latest mame now the best for Ridge Racer 1/2..
Would like to try J B’s link up RR2 also as I got 2 Logitechs Xbox G920’s
ZedEx48K
8-Bit
1,383CR
If this is modern mame you can adjust the deadzone inside it easily enough without ini fiddling, defining the pedals is a bit weird though, you have to repeatedly define it to go from axis, to +axis to -axis, this you will deff need to do with wheel and pedal set ups.
7,399CR
Iv just got latest mame to try it out ,,
Is supermodel still best way for Daytona ?
yoganuggy
639CR
Mame is almost preferred for m2 at this stage. One of the super model developers Mathew Daniels took an interest in it and has made a tons of updates over recent months.
For link play though you still need m2 emulator for all the sega m2 games and the jbmame for ridge racer.
Keeping eye on this commit:
It has the code for link play for a bunch of systems including m2 and namco racers but it's languishing there for months unfortunately.
M3 needs supermodel as it's not well emulated in mame yet.
