CRT Yoke Wiring
jerryspaghetti
32 (100%)
1,792CR
I need to add the 4 wires to a new yoke. Is there a simple way to identify which connection is which?
The yoke I have has 5 pins so I guess one is not used.
jerryspaghetti
32 (100%)
1,792CR
Toei TC 252 but I know what to plug in on the chassis. It’s the yoke that I have to wire itself.
There’s usually 4 connector points in a square. I understand the two nearest the tube are the vertical and the two nearest the neck board are the horizontal.
I have 5 pins in a straight line.
I guess if I use an ohm resistance meter that’s the only way?
