Phoenix PCB Repair
2CR
Hello everyone,
I bought a defective Phoenix board at auction, which displays graphic garbage (pic2) and emits a siren sound. It appears to be an Irecsa / G.G.I. Corporation board (pic1).
What I have done so far:
- Checked and replaced the CPU
- Checked the SRAMs and replaced 2 ICs
- Read out the EPROMs and burned 2 new sets
- Checked most of the logic ICs between the CPU, RAM and ROM
- Checked address and data signals with an oscilloscope
- Used Phil's test ROM
I used the original MB8516 and newer 2716 and checked the contents several times. Depending on which set I use, graphic garbage still appears and the CPU continues to run normally.
With the second set, I'm seeing some very strange behaviour. There's still graphics garbage, but the address lines stop toggling (starting with the CPU).
When I use Phil's test ROM, the test seems to run, the image stays at the RAM test, but no error is displayed (pic3).
When I adjust the test ROM (according to Phil's instructions, so that the error output is displayed a few lines further down), the test no longer runs at all (pic4).
Does anyone have experience repairing the Phoenix PCB and have any tips?
Thanks!
philmurr
46 (100%)
2,329CR
I have tested the modified code you sent me and it works as intended
If your original test ROM runs, but your modified test ROM doesn't, then it is a problem either with how you have burned the modified test ROM, or the EPROM itself
4,221CR
Check the connectors that the ribbon cables plug into that connect the two boards. They have lots of pins and if one is broken then that can cause issues.
