Kung Fu Idiot
AndrewM45
68CR
Hi
Got Kung Fu Master bootleg pcb
Irem converter to Jamma
Gonbes Cga to Vga thingy.
Want to plug into jamma can w lcd monitor (currently running a pandoras box)
Monitor connects atm via a vga cable directly into pandoras box
From researching the gonobas widget should be then connected - can see monitor plugs on there - but how do I plug it into the KFM-Irem board ?
4,191CR
If your cha to vga thingy doesn't have RGB input you won't be able to do it.
It would require the addition of R,G,B and sync wires to connect from the jamma side to the converter.
AndrewM45
68CR
Its got rgb input. Enclosed photo. Just dunno how it connects to the board/Item jamma converter.
4,191CR
Look up jamma connection. That will tell you which pins on the jamma connection are R,G,B and sync. Connect those to the correct input on your adapter.
