Wonder Boy - minor sprite issue
5,632CR
I got 3 of them !! None working though or I could test to make sure its not a factory upgrade fault. Very possible and people just not noticed maybe ?
Anything is possible, I guess. I'm pretty sure this version is the wboy2 romset in MAME which doesn't have the issue, but I don't know if this is meaningful, or not.
6,994CR
Wboy2 (I think) was used on multiple boards including the original ones that are not factory upgrades from Up 'n Down (As far as I know). The architecture of the boards are different and the logic is not the same so its possible , shot in the dark though as I am just guessing as such. Dont want you going to far down the rabbit hole Alice ! looking for something thats on all boards (If that makes sense)
5,632CR
I had a look at the Up n Down schems today, and used it to SLICE around, but didn't find anything obviously faulty. There's also a few ICs underneath the daughter board that I can't access to SLICE.
Looking at the schem, there's a couple of customs used in the sprite circuit, so I can't do much with those.
I did notice that the 4 data lines of one of the sprite RAMs used in the circuit are also piped through a nand gate that connects back to a custom, to a pin labelled OBJEND.
Could this be used to signal when a sprite scan line has ended, or something?
I think this is just going to be a 'bug' I'm going to have to live with, but now I've spotted it, it's really distracting while playing. Lol
5,632CR
Yes, it still does it in cocktail mode. It's just on the other side of the sprite for player 2, as everything is up-side down (if you see what I mean).
It seems to be affecting all 'end pixels' that are followed by a blank/transparent pixel in the scan line. Probably didn't explain that very well. lol. It's weird.
