7,329CR
Spent some time with this monitor this evening …
Found a couple of things
1 …. One heat sync is sparking if I touch it with a ground wire
Short on pentranic ch 288 heat sync
And the second is
The interfearance I have narrowed it down to the brightness circuit ..
Pentranic ch288 cga interfearance on the brightness
So I guess in regards to the heat sync I have a short somewhere.
Not sure if video of the interfearance which only appears now when I turn brightness pot up helps narrow down a possible reason for it?
7,329CR
is there a transistor on that heatsink? does it have an insulation sheet?
Transistor yes ..
I will have a look at the insulation sheet ..
Funny thing is …
The pin and Cush effect when I add ground to the heat sink I cannot correct it ?
Which has left me scratching my head because screen has nice geomatry as is..
7,329CR
why are you adding a ground to the heatsink?
I’m trying to find out why I have interfearance
I have added A ground to main heat sink ..
Added a ground to monitor frame ( for dag wire ) kneck pcb .
Each ground added improves the interference.
Só I was looking to see if I could find another place that when grounded improved the interfearance further .
not to add a permanent ground but more to try to track down where the interfearance is coming from?
7,329CR
i still think its completely wrong type of tube for the chassis
I think your right.
I have always thought that.
I’m really happy with the picture though it’s great apart from the interfearance .
I can dial the interfearance away. I’m just trying to see if It could be removed?
I’m thinking I have a short in the brightness circuit ..
As this heat sink obviously has a short then all ground planes around it must have voltage on them also ?IMG_8218.jpeg
I have image nice ..
Now and can omit the interfearance lowering sub bright & brightness , and flyback .. but it nags me that it’s still something possibly that could be ironed out .
I have no idea if it’s in the brightness circuit , but when brightness pot on Controll pcb is turned up Thats when the interfearance reveals its self.. like a sparkling aroumd edges of anything colour against the
Black back ground.
Or if this is something causes simply from a wrong value yoke and chassis Combo.
