A noobs adventures in cab ownership!
ChrisBEANS
761CR
thegreathopper said:
Only 200? You at least need a pair of One’s for your games room.
To be honest... I’m actually thinking... OLED, Sonos sound bar, and a Sinden light gun so I can play Virtua Cop and Time Crisis...
But I’m also trying to be as sensible as possible.ChrisBEANS2021-06-07 21:20:54
SIE
117CR
ChrisBEANS said:
SIE said:
I use Kasa plugs. They have never needed a reset which some apparently need from time to time. Very easy to setup and pretty cheap.
Got them, and they work great!!! Great tip, thank you :)
I don’t have ‘Alexa’ to turn it all on by voice, but I’m also looking for an excuse to pick up another Sonos speaker to expand the network to the game room, and apparently Alexa is built in to the new ones...
Looks like you just cost me two hundred quid!!
Money well spent
SIE2021-06-07 22:51:26
ChrisBEANS
761CR
I may have... (I actually just have)... bought another cab!
Not a project at all this time, maybe some slight cosmetics, but it’s a real fun one and I’m excited :)
I’ll let you know when it arrives, but in the mean time plenty left to do on these two.
Updates soon I hope :)
TonyC
9 (100%)
77CR
You don’t hang about do you Chris!
Good luck with the new project, looking forward to the pics
BTW, I’m been trying to 1cc metal slug and struggling on the last level, did you say you have a video where you did it so I can get some tips ?
ChrisBEANS
761CR
Big update, just dropped the U4 chassis to Grant and when he looked at it it was immediately apparent what’s up.
The board itself is physically cracked, fairly badly, so he’s going to repair all the tracks and hopefully it’ll be good to go!
It’s actually really good news as the fault seemed ambiguous in use, so I was worried it would be hard to track down or rectify...
ChrisBEANS
761CR
https://www.twitch.tv/videos/652901859
I’ve lost the video of my first ever 1cc of it :(
However I persevered with the game after that, and the video above is my first no death clear.
The video is pretty sweary, but I don’t think (??) that’s banned on here. Genuine apologies if it is...
ChrisBEANS
761CR
So, the U4 chassis is back, I’ve managed to get it back on without knackering it again, and now I just need to dial it all in and I’ll happily post some pics of it up and running
Grant’s a bloody wizard!!!ChrisBEANS2021-06-19 12:53:02
ChrisBEANS
761CR
So I've had the U4 on now for a few hours. I've even given it a bit of a nudge (not too much of course!!), and no shorting whatsoever, played a few games on it too.
Looking pretty good!! It's not dialled in perfectly, which is strictly down to my incompetence, but it's pretty close!!
I'm told that there were four broken tracks, and a couple of prior repairs were replaced too. Hopefully this should last for years to come now.
One thing I'd really like to say about Grant... not only is his work impeccable, but he's very reasonable with his pricing, he's very quick, and after he's been paid and I've taken it away with me he's checked in with me a couple of times. Firstly to make sure it was all working correctly once I got it back on, and then hours later to make sure that it was still running ok as the prior fault was intermittent. Can't say enough good things.
I'm finally down to cosmetics with these cabs now. EL panels for the big boy, which will then basically be finished, and a bit of powder coating and a set of EL panels for the U4.
I'm also looking to get the CP housing of the U4 chromed... thoughts?
ChrisBEANS
761CR
So the new EL panels for the big boy six slot have arrived...
What's awesome about the fact that they're modular, rather than the original panels which came in two panels of 3 EL panels each, is that I can now try them out in the U4 too, see if there's a way to fit EL panels into a cab that was never meant to have them.
The main benefits of EL panels on the U4, depite them not being 'authentic', is that the flourescent tube is very bright, creates light bleed, and is actually quite loud and buzzy too.
The EL panels should eliminate all of that, and I think will be a little cooler too.
I'm sure it's been done before, but I've never seen a U4 with EL panels, so fun to have something uncommon, if not unique too.
TonyC
9 (100%)
77CR
Watched that metal slug video Chris, was actually really helpful in some areas I am struggling with. Still using 2 continues at the moment to complete it but I can beat the end boss only losing two lives now so getting there, just really struggle with that bloody last level. Need ninja skills with some of it (and a good memory !) good luck trying to 1cc the other slugs, I won’t even be attempting them. One things for sure, the game is absolute class !
ChrisBEANS
761CR
Glad it was useful, dude.
There are MUCH better videos on YouTube, but you’re right, to 1cc it it really is largely a memory thing.
It’s only mission 6 that’s any trouble really, so if you’re really chasing a 1cc then maybe emulate and use save states to just grind mission 6 over and over.
ChrisBEANS
761CR
The above panels are from www.neogeoledmarquee.org, FYI, and I have to say that the bloke who makes them is spot on.
Before attaching the panels to the cab, I tried a dry run with them all connected externally just to make sure everything worked... and it didn't.
It was doing all sorts of weird stuff, like not ligting the correct panel for the correct slot, certain slots not lighting at all, and other strange things.
When I carried out the tests that the control board is capable of, everything ran smoothly. Upon boot up, the control board would light panels 1 through six in turn, and in test mode I could light each individual panel no problem. It was only when actually running games or in hardware test mode on the MVS that the issues persisted.
I took a brief video, and e-mailed the guy who makes them. Absolutely to his credit, he replied almost straight away, explained that as it's a small operation he personally tests everything before dispatch and that he though the problem might be with my MVS motherboard, however, he had a couple of simple things in mind that were worth trying first. One of which was to check the connections on the cable between the MVS and the EL panel control board.
Wouldn't you know it, one of the wires was half pulled out of the connector. Pushed it back in firmly, and everything ran perfectly :cool:
So... attached the new EL panels to the marquee with masking tape at first, just to make sure they lined up correctly, and then screwed them on for good using the supplied wood screws straight into the cabinet itself.
Tucked all of the cables through, and gathered them up behind. One really silly mistake I made here was not to label each ground wire for each panel, and so I then spent ages tracing each one back to match it to it's respective live :shifty:
Now, the original control board sits on the reverse of the panel on which the panels are mounted, but this is actually a ball ache to get to as you have to remove the whole panel, unplug all of the marquee lights and speakers etc to do anything to it. Not to mention the fact it's reasonably heavy, and awkward size and shape, and is six feet in the air making it a pain to remove.
I decided a much better place to mount the new control board was just behind the back door.
(please excuse the wiring, I'll get to tidying it all up soon enough!)
Now I can access it to use the test mode, and there's also a nifty ability to change the brightness of the panels too.
Time to give it a brief test...
Sweet!
All this thing needs now is some internal cable management, the memory card slot wiring up, and I think I can call it done!!!
From a sad, very rusty old beast, with bits missing, filthy and old controls. extremely loud fans always at max RPM, bits not working, damaged and discoloured CP art, and a very dull and lifeless screen... to the clean, tidy, silent running cab with a very vibrant screen (thanks again Grant!!) and a few quality of life improvements like the coin button and crispy and heavily modified Japanese sticks, I think my first attempt at a restore has gone OK.
Not least of course, because of the help, advice and encouragement I've recieved here :)
TonyC
9 (100%)
77CR
nice work Chris, think you need to remove the ‘noob’ tag now though!
Sounds like you had a crash course in how to fix a cab and have got the bug
tt_rage
76CR
Honestly, I WILL get that bezel scanned and over to Muddy. Been a little bit ill recently, so apologies for the mammoth wait.
Cab looks awesome. Well done Chris.
