I can supply you a new replacement computer, ssd, graphics card to drop in no problem if needed. With latest version v1.03. Fixed alot of these for peopleHi, got one of these in the arcade that has given up on us. It had a new hard drive last year. Not sure if the 329Mb for the ram is a thing or not as bios registers that it has 2 slots with 256Mb in each. Any advice or a push in the right direction appreciated as I'm clueless with computers.View attachment 41227View attachment 41228
Thanks, that was my initial thought, but I wondered if anyone could suggest the cause of the error? VGA i, I have not amended a anything since I purchased the cabinet last year, it has worked well since purchase.run the recovery disks, what video output are you using? vga, dvi or hdmi?
As above i can supply new computer motherboard & graphics card systems with latest game software if needed. Proper systems, not emulation or multi game. I can also supply the recovery disks if requiredHaving an issue with boot up, game ran perfectly yesterday - any thoughts appreciated on best options - do I need a re install, and what is likely cause? Thank you
Thank you - this might be the way to go for reliable future use I assume - how tricky is installation to get up and running again, I am at best of average skill set with IT matters, so is there support for the conversion to your kit, clear instructions etc that I am likely to be able to complete the change with? I appreciate your help!As above i can supply new computer motherboard & graphics card systems with latest game software if needed. Proper systems, not emulation or multi game. I can also supply the recovery disks if required
New motherboard, graphics card and ssd with v1.03 preinstalled. Just swap out the parts in your current case. All pretty easy. Sold lots and helped many games keep going. Can send you a dm with costsThank you - this might be the way to go for reliable future use I assume - how tricky is installation to get up and running again, I am at best of average skill set with IT matters, so is there support for the conversion to your kit, clear instructions etc that I am likely to be able to complete the change with? I appreciate your help!
