Android keyboard - HELP!
Pacman83
The Pac-Master
212CR
I've had to do a reset on my phone and there is now NO keyboard. Therefore, I can't access anything through the Play store, obviously the keyboard is needed. Any ideas?
Pacman83
The Pac-Master
212CR
ZedEx48K said:
Try another restore? Sounds like an initialisation cock up, or install one with a file manager from the SD card.
I've absolutely no idea how that's done. Any step by step? Cheers.
ZedEx48K
8-Bit
1,355CR
As long as it lets you explore around your folders etc, if so add this file* to the device and install it, hopefully that will give you a keyboard back!
*I've renamed it to not let the internet know what I'm giving you, it's not nasty just, well you know
https://dl.dropboxusercontent.com/u/46843870/file.apk
lemmie know when you have it so I can remove it
