Problem Arcade Power Supply to a 24pin power input Supergun.
daeds
11CR
You didn't mess up big time, so don't worry. That blue cable for -12V most likely isn't routed to the edge connector.
Yup, that's why I had to get that bodge wire, I saw the positions wrong on the 12v, missed the -, fixed and now working as intended, thanks a lot for the heads up mate!!
Lurch666
21 (100%)
4,236CR
You can.
But be aware that adjusting it too high could damage the PCB.
I have a cheap little LED voltage indicator attached to the +5V line so I can always see the voltage output.
channel27
1,289CR
Always turn the voltage back down again when swapping boards and recalibrate from there.
Just because it's set at 5v for one board won't mean it'll be 5v for the next one as the power draw will be different (y)
daeds
11CR
Thanks for the heads up! Toki is really one of the hungriest I have, damn ape likes volts.
daeds
11CR
Update: Power hungry Toki with it's new voltmeter!
Can I ghetto a light fixture switch thing to the power cable so I can turn it on and off? :)
