Asteroids PCB for CNP - fix log
Nes4life
1,133CR
Got an 'untested'
Asty PCB from CnP and boy did it need some work to get going!
[list type=decimal][*]Inspection:
  • DIPS need replacing (replacement not pictured)
  • Crystal (for main clock) is missing!
  • Thump capacitor missing
  • A few broken traces need patching
  • Variable resistor for Y output is broken
[*]After fixing / replacing above; still dead - no Watchdog
  • Replace LS74 at D4 to restore Watchdog
[*]Watch-dogging in test mode!
  • Lift pin 1 of L6 to test the logic section independently
  • watch-dogging still
  • Connect Arduino ICT - RAMs at D2 E2 not working
    • replace RAMs
  • Still watch-dogging and little else
[*]Remove all ROMs
  • DE1 ROM had bent pin
  • All ROMs validate
  • Realised ROMs DE1 and C1 were switched!
[*]Beep codes - 2114s at M4 and N4 dead
  • Replaced and game plays blind!
[*]Pin 1 of L6 put back - watch-dogging
  • C8 prom replaced - test grid shows! It's collapsed - see pic below the PCB.
[*]Taken out of test mode and ellipses show in play
  • Usually this is an issue in the analogue vec-section
  • Systematically socket TL081 and TL082s until issue found (dumb fix but easy)
[*]Checked all the usual suspect ICs and traces with the oscilloscope and saw nothing wrong. Piggy-backing also did not help. Initially I got the Signature Analyser out as I was stuck and I'd never used it before. Was pretty useless at this stage as all signatures verified and it actually only exercising the logic section and I knew that was working fine. It was fun anyway!
  • Whipped out the IC Comparator and it worked like a dream!
  • Faulty output on LS191 counter at F9
  • Test grid fine and game plays!
[*]Sound section now.
  • Thump sound is stunted
  • Saucer shoot doesn't fade away as it should
  • Both issues turned out to be the respective transistors at M8 and N8
  • Game works and sounds great!
[*]Fit reversible 6116 mod on request (not shown) to replace those pesky 2114s[/list type=decimal]
Collapsed grid:
Fixed!
cparsonsuk
205CR
Awesome work Phil, I've enjoyed getting the updates on this during the month of September as you've gone over the board fixing everything wrong... I hope you've "enjoyed" it too even though the Signature Analyser wasn't useful this time.
Maybe a name change to PhilAsteroids4life ? ;)
