Although Food Fight has a free play mode that can be set using the dip switch #2, once set you no longer see the fancy attract mode and the high score table is not displayed because setting the dip continually sets the number of coins inserted to 2.
While you can wire P2 start to coin 1 with a small wire soldered to pins 13 and 16 on the pcb connector to coin up when P2 is hit, this isn't an elegant solution.
With no prior assembly knowledge I decided to learn a little 68k assembler and fix this problem by hacking the roms to enable free play and display the fancy attract mode. It was an interesting project that gave me an insight of how the roms are switched, the counters used, the rom checks and recalculating the CRC so the rom check still works.
I have attached 4 zip files, one for each of the Food Fight revisions that you can use to patch your 6 original EPROMs. There are no roms included in these files only the patch files, a java rom patcher, a readme and a png to print out your own labels.
"FREE PLAY" is now displayed on the gameplay section of the attract mode and to start a game just press P1 or P2. The PCB dip switch 2 should be set to free play for this to work.
Cocktail
https://www.dropbox.com/s/e6o767cioag4kml/FF FP Cocktail.zip
https://dl.dropboxusercontent.com/u/17659718/FF FP Cocktail.zip
Rev 1
https://www.dropbox.com/s/qy8y4vrxv3epk4k/FF FP Rev 1.zip
Rev 2
https://www.dropbox.com/s/bo170i1iuorkl59/FF FP Rev 2.zip
Rev 3
https://www.dropbox.com/s/46bh5jopl5r8glr/FF FP Rev 3.zip
edwoodjnr2019-06-13 20:26:27
Cocktail
Rev 1
Rev 2
Rev 3
