Atari Tank Raid Restore!
Gaming Heaven
106CR
Hi all
I am posting this on several forums!
Someone really generous [Alpha1, massive thanks again Olly!] gave me an Atari Tank project machine
I am aiming to restore it, no idea on time frame [might be long term] but here are a few shots:
Update now is I have already been offered a marquee which I am very grateful for.
So I now need:
Marquee retainers [although could make some]
marquee surround and instructions
advice on the right substitute 24" CRT
Any advice or comments is gratefully received
I have almost finished cleaning it so will post some more pictures soon
Keep an eye out for updates!
Gaming Heaven2015-11-09 23:26:06
Gaming Heaven
106CR
sorry for the delay missed the post
the entire chasis [and neck board also I think] is missing!
I need a replacement monitor, does not have to be as old, as long as it takes the inut and outputs black and white!
Gaming Heaven
106CR
no suprise at the screen burn with this game:
cleared the old rubber matting as it was shot, so will then fill the dinks and glue some new matting on
cleaned up the CP notice the historic repair
more than 36000 plays:
remove pcbs:
the components on the other side are clearly suspect
notice the left board, there are 2 black components [just below the top left hand corner massive capacitor, are they resistors or diodes?!] that are causing the scorching:
original marquee secured as below, but I need the bezel surround with instructions
Gaming Heaven2015-11-15 16:17:37
philmurr
48 (100%)
2,362CR
2 diodes and a resistor.
Fairly standard scorching from games of this era, just need to replace them all with something a bit more modern.
If they're the same as in Breakout, I've just bought some RL257 (2.5A) diodes and have a spare couple if you want them?
philmurr
48 (100%)
2,362CR
From the schematic they look like MR501's which are quite high current (at least 3A)
You might want to consider converting to a switcher which I think might be more reliable for this board.
