AZTARAC - It Lives!!
5,526CR
Jeff,
I'm surprised you didn't build it in a Centuri cab like Pheonix/Pleides etc - you could have had the sides painted up then and bought a repro panel off Archer
jetusenet
53CR
Alpha1 said:
Jeff,
When I purchased the board-set, I was told that it was a project board, and it turned out to need quite a lot of work before I would be able to apply power to the set. I was hoping that all my work would pay off but you never know.
That being the case, I did not want to start a "major" project as I am hoping that one day a dedicated cab will come my way. As I have a very nice Space Duel game, (spare), I pulled the boardset and wiring harness and used it as a testing / playing station with the intention of one day transplanting everything into the dedicated.
I did speak with Arch who went out of his way to help me with sizing the repro CP and it just would not work in the SD cab without major mods. Also as I do not have an actual flight stick from Aztarac, I would have had to modify the CP to accept my fabricated replacement and that would have ruined the CP for future use if I did come across the actual stick.
Taking all these factors into consideration, the best and fastest was to use what I had and to get the game up and running as soon as possible. I am still working on the replacement stick and should have that done in a month or two. I still have to dial in the display and find out once and for all if I will be able to use an Amp stock or need to utilize an adapter of sorts to modify the output of the PCB for the display.
I enjoy these challenges as I don't do crossword puzzles............
Jeff
jetusenet
53CR
DanP said:
There's some serious dedication gone in there Jeff. Kudos to you!
Dan
Thanks Dan, much appreciated.
I was planning on updating my project with shots of the display but my family is currently sick, coming out of every.... well you get the idea. So I'm basically just sitting and waiting for the next "clean up".
Wish me luck
Peace
Jeff
jetusenet
53CR
OK, I finally had the chance to get the video up if you want to check it out.........
http://www.coinopspace.com/forum/topics/aztarac-it-lives
Jeff
DanP
Administrator
2,195CR
Wow Jeff, that looks pretty damn good. I suspect Aztarac is a game you can only really get the most out of with the real controls. What is it supposed to have?
Dan
jetusenet
53CR
Dan;
The game uses a couple of buttons, an optical spinner, and an optical joystick. I an using the original CP from my SD so I first have to fill all the holes, layout the new controls, drill and cut the holes, paint the panel and install the overlay.
I am going to use standard leaf buttons, a spinner from a Tempest and a control stick from a Red Baron, converted to an optical. I will remove and replace the handle with one from a Mad Planets or similar which is the same one that originally came with the Aztarac.
Should be a walk in the park!
BTW, thanks again for the compliment.
Jeff
jetusenet
53CR
Making progress if anyone is interested:
Also going to have the bezels repo'd
http://www.ukvac.com/forum/forum_posts.asp?TID=329086&title=aztarac-bezel-reproductions-any-interest
Peace
Jeff
