Black bezel material stuff?
Ronnie Dent
1,116CR
This will be fixed dedicated vertical, ideally would want it in one piece roughly 600mm square, not sure that foam board is the stuff I’m looking for ? The foam is sandwiched with thin pvc
Cheers Ronnie
Venom
710CR
Possibly a type of foam Board ?
What size monitor have you got ?
I was making a few replacement monitor surrounds last week . I use heavy duty grey card (hobbycraft ) sprayed with matt black - Lordsvale project.
I did exactly the same for a LCD monitor replacement when a CRT died but did manage to get Black from hobbycraft. How did you cut yours out of interest as I went through a couple of sheets :) Yours looks almost perfect !
Flyback2021
35 (100%)
1,855CR
Cheers mate!
I spent a fair bit of time as made 4 different version of black bezel for various 20” monitor surrounds.. I traced the 20inch monitor and then made a template onto mdf which I then used to cut out the heavy duty card . The reason I go grey board and then spray Matt Black is the surface has less reflection and card is easier/ cleaner to finish than foam board.
Sometimes I use a spade drill bit if the months frame bolts need notching out.
