I have an Afterburner here that I'm restoring. On both sides the side art has giant bubbles (more like huge single ripples), in places enough that you can thread things underneath the art from one side of the cab to the other. Picture:
http://www.system11.org/temp/forumposts/cabpics/Afterburner/3.jpg
It looks like the glue has basically given up, and over repeated heating/cooling cycles the art has expanded/contracted and formed these ripples. You can clearly see glue tide marks where you'd expect to if this was happening. The glue is pretty pathetic, you can peel the art up safely with very little force, which leads me to two possible solutions.
1) Peel up the areas affected as far as 'good' parts, then clean the glue off the folded back art and the wood, apply glue and firm back down. Possible downsides are the area without new glue starts shifting instead causing the same problem, and the area where it's being folded will be hard to apply glue to.
2) Peel the entire bit of art off, clean the glue off the back of the art and the wood, put on new glue, re-apply. Difficulties here surround lining the thing up properly, as I'll be having to use glue which doesn't give a huge amount of repositioning time. It will be tricky to get the same quality of smooth finish as the original adhesive.
I've already tried just peeling it and firming it back down, it starts to lift in a day or so, and formed lots of bumps due to clumped up glue. I'll be cleaning the glue off the art and wood with an alcohol solution.
So - has anyone done this before - recommendations?
bloodflowers2010-07-02 11:16:11
