can someone tell me???
ale76
9CR
i just recently bought an arcade machine :) now the machine had no jamma pcb game within it what will happen if i turn the machine on with no game inside????? i wish to turn it on to see if its working as its untested ..... so if i turn on the machine from the power supply will i cause any damage at all without a game inside?? as i dont wish to burn anything out
"newbie" please help in answering this question
andyman
1,059CR
Assuming its a Jamma cab, that will be ok but don't be nearby when you do, untested usually means knackered. Put it on a switched extension lead so if anything happens you can switch it off quickly
Andy.
ale76
9CR
also how do i replace or put on a new jamma harness ,any information would be grateful and helpful?? understanding the process and what colours go where and do what ??
ale76
9CR
thanks andy :) so you mean turn it on and stand well back lol when i turn it on what actually should happen and yes it is a jamma cabinet
andyman
1,059CR
Marquee lights up (if it has a light), coin slots light up (again if they have bulbs), monitor crackles and has static on the tube front, maybe an orange glow from the back but not always and you have light(s) on the psu. Click here for Jamma connections
Andy.
ale76
9CR
you say assuming its a jamma cab its and arcade machine with a jamma harness inside ... was wondering what else could it be otherwise ???? i see the word jamma which i understand but what is pcb about??is this just the game board :)
ale76
9CR
i have jus connected my blue elf 2009 jamma pcb it cam on working and sound :) the only problem is i have no coin part working also no buttons or joystick controls also on my jammma harness there is one black cable not connected to the jamma harness any idea what this cable may go and what it may be connected too and is this part of my problem i guess i may have to trace it within the jamma cabinet ,any help on using the blue elf 2009 jamma pcb would be much appreciated thank you
G
Guests
Guest
this section of the forum is for new users to say hello, please use the tech section in future for tech posts
G
Guests
Guest
That's ok we were all new once, just use you common when posting, look at the sub forums names and see which one best matches you topic or question, some people may only be interested in certain parts of the forum, and if you post in the wrong place, you might not get all the help you need.
