chihiro type 1 problems
Setch
The nice ad-min
538CR
silverfox0786 said:
I don't have the first clue how to help you but here is RETROREPAIR selling a upgrade from Type 1 to 3 kit
http://www.ukvac.com/forum/fs-chihiro-type-3-512mb-dimm-network-board_topic338578.html
MO sells these for £80 at videotronics, a bit overpriced that one IMO
Outrun2
Colonel Outrun
1,120CR
The only thing I can think is something simple like the VGA cable is passing too close to the PSU or base fan or something? The VGA connector on a Chihiro is located on a different side to a Naomi so maybe you've re-routed the cable in a way it doesn't like..??
This sounds ridiculous I know, but I did have some very strange picture problems once when I was testing and had the cable accidentally draped over the FFB drive board!
griffo83x
30 (100%)
597CR
cheers i will go and try and have a mess with the wires now , dont think i had to move the vga lead though
Setch
The nice ad-min
538CR
Have you tried putting the Naomi back to confirm it still works as before ?
Worth also switching VGA cables and psu from your naomi just in case there are any issues here! simple things to try, you might get lucky.
Otherwise snap some pics of the internal setup so we can see how you have it all wired up.
griffo83x
30 (100%)
597CR
yes the naomi is back in the cab and running no problem ,i will take some pics over the weekend when it put the chihiro back in
griffo83x
30 (100%)
597CR
back again just connected it to my pc monitor and is working fine , this is now running on the id cab
so it runs ok but not on this monitor in the cab , still non the wiser ? the naomi 2 runs fine
cab
griffo83x
30 (100%)
597CR
bbz149 said:
Did you connect the PC Monitor using the cable from the back of the Monitor in the cab? Worth a try!
yeh i used the pc monitor cable from the chihiro into the cab monitor , still no difference ? it has to be something with the monitor
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
have you tried with a PC monitor that's known working. I believe they are also 31khz
EDIT: oops dumb ass me I didn't see you already done that silverfox07862014-05-09 23:51:29
ZedEx48K
8-Bit
1,307CR
There is one workaround to this, you could swap the monitors around in the cabs, both the same size if I remember, also while doing so if they are the same parts test the chassis's out on both tubes to see if you can help identify possible issues.
Ordyne
1,275CR
Id try to adjust the horizontal hold on the chassis before swapping monitors out, IIRR its VR442 marked H.Hold near the video input on the chassis.
It should be factory set and have some sealant on, if that's been picked off you know someone's been nobbing around with it.
Chihiro is a slightly different frequency to Naomi, IIRR theres about 0.5Khz difference. It should work on your 29E31S but it doesn't need to be out much to cause a problem.
Hope this helps
griffo83x
30 (100%)
597CR
Hope this helps
cheers i will have a look and see if it makes a difference , i hope so i really dont want to be swopping the monitors over
griffo83x
30 (100%)
597CR
ok then i have tried altering the horizontal control on the side of the monitor chassi
but it still wont sync
here is a vid of it running, this is about as good as i can get it , any more ideas anybody ?
https://www.youtube.com/watch?v=DpLTc0JgmKk
Ordyne
1,275CR
erm, id stop adjusting random pots seeing has you've been adjusting the facotry set HV level!
Have you been adjusting the H Hold pot while you can see the picture ? IE with a mirror?
You've got little chance if you are moving it a bit then having a look, also someone helping you is normally a nightmare unless they are clued up.
Other than that if youve tried another VGA cable it looks like a chassis fault. Just watch it with the VGA cables as some have various grounds connected and others dont. They arent all the same which doesnt cause a problem on PC stuff but does on amusement equipment. I've never had a problem with any Sega hardware though so it's a long shot.
griffo83x
30 (100%)
597CR
hi , yeh i have give up with messing with the monitor now, i have put the naomi 2 back in and it works fine, i did not have to alter the setting it worked straight away
yes ihad a mirror when i was adjusting the monitor , i have tried another vga lead i dont have any more to try but the one in the cab would not work with the chihiro , and the one on my pc monitor gave the same results, but worked fine when i connected it to a lcd screen.
i have another monitor in my naomi cab and the chihiro syncs with that . so im gonna swop the monitors over at some point, just waiting for martin do deliver another daytona 2 so i can take the steering from it and swop it all over at the same time :)
many thanks for your help and everybody else who tried
cheers paul
Outrun2
Colonel Outrun
1,120CR
All very strange..
Make sure the monitor in the Naomi upright is a Sanwa too before swapping. If it's a Nanao you'll need a differrent monitor bezel once it goes in the iD cab as the two monitors have different screen curvatures.
Not a big problem but it would be a PIA if you only found out after all the trouble of swapping monitors!
