Choplifter Repair
GadgetFreak
961CR
I bought this "untested" Choplifter off Ebay and of course it was faulty, funny thing that as all his other boards were tested!
It's actually a Tecfri Licensed version but is identical to the Sega.
Anyway after the standard delay it starts with the tests, does the full screen flicker bit then just as it starts with the descending blocks it comes up with "BAD IC 0002". It's an 8k ram which is normally soldered but this one has very recently had a socket put in!!!!!!!
Anyway tried a known good one but still errors, so it's not the ram. You know whats coming...... I fire up my "Slice" tester and start working through the chips associated with the video ram access. Within minutes I get the following from IC24 a 74ls155.
So I dig out my existing board and get the following:
So I cut out the '155, socket and replace, board is now perfect.
This is the kind of chip fault that I would have difficulty finding with a standard logic probe, the pins are still active but not quite correct.
The next step for this board and the reason I bought it, is to convert it to a System 2 Wonderboy when I find the time. Someone, I can't remember who, asked me to get a proper Wonderboy decrypted so now I have the board the only thing holding me back is time. First up is getting "Slice" out for some Beta testing then I'll get to work.
TheDaddy
14 (93%)
7,223CR
Nice repair. What tester are you using for the ttl chips ??? I have a choplifter I was thinking of converting, Bootleg though so prob not worth it plus I just repaired a wwonderboy bootleg that is pretty good.
Dave.
GadgetFreak
961CR
It's my own tester which is in Beta testing at the moment. I will have it for sale soon
Don't think you could easily identify this kind of problem on a scope or even a logic probe. The outputs were changing but not properly. The sample size for the above pics was 2,000,000 5ns samples, pin 6 was low for 3% of these but had an incorrect state for only 1932 samples. And for pin 10 it was low for 1% and had 767 bad states.
It's these kind of errors that my tester excels at spotting.
TheDaddy
14 (93%)
7,223CR
Brill software - I love Beta testing for people :). How much are you selling for ?? What type of reader would you need ?? Sorry for questions, Always looking for better ways to test things. I Am just using an IC identifier and MiniPro - Does a good job to be fair but cant have enough kit.
Dave.
