Dead Asteroids fix log
Nes4life
1,133CR
Got another Asteroids PCB that is nearly fully resurrected.
Issues:
- logically dead but getting correct power. Someone had stolen the 12MHz crystal! £1.70 and 2 days later I have a handful of crystals and the game gives me beep codes
- Beep codes point to the 2114 at R4 being dead. Ripped it out, socketed, and replaced.
- DIPS are smashed - replaced DIPS (can be confident they work now)
- Game plays garbled and test grid only shows crossing points. Working backwards from the DACs I see that the signals coming out of the LS374 at B10 (Y-signals) do not match the signals going in. Ripped it out, socketed, and replaced.
- Got a very familiar arrow head pattern < > (see pics below) showing an X-axis issue. Experience tells me its the LS374 at D10. Ripped it out, socketed, and replaced.
- Game plays but text becomes tiny and left-aligned on the screen. Turns out the LS14 at B6 has pin 4 stuck low. Ripped it out, socketed, and replaced.
Here's a picture of everything I had to replace to get it to its current state:
Here's the R4 2114 RAM replaced and the DIPS still needing to be swapped out:
THEXfsl.jpg2
Here's the random crossing points only on the test grid. For future reference; this means that both LS374 at B10 and D10 are dead!
SvtTRQV.jpg1
Here's the familiar issue when there's a bad X-pos LS374 at D10:
Ow7j7qi.jpg1
And here's the missing crystal (yet another reminder why you should throughly look a PCB over on both sides before hooking it up - your eyes are a great diagnostic tool):
Jpe7pwm.jpg2
So, that leaves me with the current state. Game plays and sounds great but when you get to the 'enter top score' screen all the text is left-aligned. I also now notice that all in-game text is tiny:
PFnEaH2.jpg2
In the cab (before fixing text issue):
ctrJykd.jpg1
And finished:
BA45N9l.jpg1
Nes4life2018-02-07 20:41:28
Mitchell Gant
888CR
You're getting good at Asteroids fixing there Phill! Great stuff.
Missing 12MHz crystal is a classic easy-to-miss fault, as it gives a very dead board for the unwary.
Broken DIPs seen very common too. Not sure why? Maybe from people stacking PCBs, it rips tops off?
Text all aligned to the left is a new fault I've never seen, and I can't think of a simple reason what could cause a fault like that either. Pretty sure text drawing position is coded into the software, so wonder how a hardware fault could affect that?
Nes4life
1,133CR
I’ve a feeling the text is not really left aligned but just small. The starting x position remains unchanged so it appears all text has gone left. It must be a bad scale signal.
Nes4life
1,133CR
Fixed it! The LS14 at B6 had pin 4 stuck low. Replaced it and all is well.
Saw from a few repair logs online that as well as the 4 scale signals there was also DVX11 that affect sizes. Followed the signal about and it led me to B6 and I saw it misbehaving on the scope.
J4hWJVP.png1
BA45N9l.jpg1
Nes4life2018-02-07 20:37:23
rushfan86pw
5CR
Sure wish you were my next Door neighbor . I have an asteroids cocktail that is dead. Replaced big blue,and have done some other minor power supply testing with a multimeter, but it is very overwhelming to a newbie repair guy with 10 arcade games.
I will inspect the pcb and see if anything looks funky. Thanks for all the info and pictures.
