Dead Bomb Jack
big10p
Coins detected in pocket!
5,625CR
Was working fine until I fitted a high score save and freeplay mod, now it's completely dead. Zero sound or video. I replaced all the original chips but it's the same, so I guess I broke something along the way. ☹️
Voltages seem fine and I probed the CPU which does look like it's active.
Any idea what could have broken that's killed it so completely?
big10p
5,625CR
Did you remove other roms? Bent pins on ICs is an common problem that happens when insertig an IC.
I'm usually very careful when fitting ICs but I will check. I think I may have removed a different ROM to do a romident.
Just remembered that when I probed the CPU, the RESET pin looked like it was pulsing (not really sure how to use my probe properly, so not totally sure). Does that mean something is constantly causing it to reset?
big10p
5,625CR
If the reset is pulsing, it means the program is not running. Maybe you swapped the eproms or something like that
I'm sure the ROMs are in the right place as they're all numbered in sequence. I think I'll try verifying them all with the MAME romset tomorrow.
big10p
5,625CR
OK, all the ROMs verify with the MAME ROMset.
I now realise that the D780C CPU that I probed on the top board is probably just used for sound? There's another one on the bottom board which looks like it's functioning. RESET pin is high and I'm getting pulsing on all data and address pins, except A15 which is constantly low, but maybe addressing isn't getting high enough to use it? Just guessing. I tried swapping out the CPU for a spare Z80 I have, but made no difference.
Pretty much stumpted, now. Anything else I can check?
sukhbir
45 (100%)
1,608CR
Check the CS,OE,RW pins on 1E and 1H of the work rams,they should have activity. Also close to the work rams should be 5 program roms,Check the CS pins on all they should also be busy.
philmurr
46 (100%)
2,313CR
What did the high score save/freeplay mod consist of?
Can you post a photo of the board now with everything replaced back to standard?
big10p
5,625CR
I did the mod using Arcade ROM Patcher which patches ROMs 9 and 11, and requires the ram at E1 be replaced with a DS1220.
Bottom board
Top board
4,567CR
Should the boards not fit back-to-back (so solder side go together, whereas you have them plugged in "backwards")?
I don't know for certain as I've never owned one, but that's how boards usually are
Yeah it should be on these, not all pcbs but yeah good spot
The old saying a Picture is worth a thousand words is certainly the case here or hours/days of head scratching
big10p
5,625CR
OMG, I didn't even consider that. I can't seem to find a good enough pic of the board online to confirm. Should I just try it?
Lurch666
21 (100%)
4,202CR
If you have a multimeter check the +5 and GND from the edge connector to a ttl on the bottom PCB.
Don't just try it in case it messes something up.
