Dedicated PCB for Space Harrier / Buck rogers
joe.lait
22CR
Hi,
I have a dedicated Buck rogers and I have a few pcbs but sadly they all now have graphic glitchs, so ijm looking to get something reliable Is there a mame type pcb that you can have two dedicated games on and thats it.
1. Buck rogers
2. Space Harrier
I would like it to be easy to setup or buy it pre configured the wiring up of it is not a problem.
Body pop
24 (100%)
1,031CR
Would you not consider getting the pcbs repaired ?
I doubt there’s anything available,like what you are wanting
Maybe stick a pc in it with mame
,try and leave most of the cab unharmed though if possible
4,741CR
Not many Buck Rogers over here, Sitdown or Upright?
Not really a fan of the The Zaccaria cabs myself but wouldn't say no to these if I had space
Noticed there was a Buck Rogers PCB on ebay recently £100 untested, still on
just looking at this sitdown and I have Joystick from Buck Rogers they are Microswitch and Space Harrier is Analogue pots so mame is probably best bet being able to use switched joystick in mame for Space Harrier
Older DOS version would be good really, for booting and turning off
To run Space Harrier in MAME using a DOS environment, you will need a legacy MS-DOS MAME build (like MAME 0.37b16 or earlier) to run on a physical DOS machine, OR use an x86 emulator like DOSBox-X to emulate DOS on a modern computer. [1, 2]
7,326CR
Soundblaster 16 sounds great in a ms dos mame build
Mono
I have a macrium hdd image saved set up for sb16 dos mame if you ever need a ready made image
4,741CR
Mono
The Awe32 sounded amazing on The Ninja Warriors and Duke Nukem 3D with the reverb, need to get that back running to hear it again as i have Awe64 card, still got System16 Emulator i used
