Dehumidifiers
ZedEx48K
8-Bit
1,399CR
Saw these today in my local Aldi, thought they might interest some of you
Priced at £34.99
Spanky
632CR
I got one of them a while back, they're sh*te.
It does work, but I left it on 24/7 and it iced up at the back and the DC plug melted. Just go down to Screwfix and spend £130 on a proper one.
andrewsm
485CR
See it works using Peltier effect. These are electronic devices that heat and cool depending on which way the voltage is applied. Problem is they take lots of current to work well and hence why DC connector prob melted. Maybe not intended for constant use? I had a freezing kit once that froze pipes. It used these and was drawing many amps. The device will only reduce the temp by so many degrees so the heat it transfers is sucked away by cooling pipes like a heatsink. That way it can go lower than ambient. Im guessing at that price it wont be engineered very well.More expensive units will use a compressor and gas like fridges etc. andrewsm2017-01-26 11:08:21
4,883CR
The weight tells you all you need to know, 2kg
can't be much in it
I've got a really top make one here, not sure if it works but there like £200+ new and it weighs like 13kg or something
I need to test it, how long would you need to leave it on before it starts collecting water though, I've left this on over night and nothing in the tank in morning, put it in bathroom after bath as its only place with loads of condensation
Shinydaz
807CR
I recently brought an EcoAir DC12 off Amazon, it's certainly doing a good job so far. This cheap small one looks to have good reviews and is reduced in price.Shinydaz2017-01-26 14:10:06
Brettster
20 (100%)
1,233CR
can't be much in it
my Eco air will pull 2L of water a day in winter / humid days
my wall clock thing says the ambient humidity in my send is 50 - 60% but it still manages to pull that out of the air
I leave it on 24/7 just have to go empty it every day. I dont want to drill another hole to have the pipe outside
tb2000
3,315CR
I got a cheap Babz one off eBay, only was about £35-£40 and uses a peltier as above. Runs off a supplied adapter (looks like a laptop charger!) Works fine though, I left it on for three days straight in my car a while ago, filled up the 2 litre bucket at least half way!
maskeddev
88CR
I got a cheapish one, around the £50 mark. After a couple of weeks, one of the wheels snapped off around the cheap sh*tty plastic. Wish I spent proper money on a proper one!
