Brettster said:Just tried mine for you with a pc and Jpac
at first it wouldnt sync either, I removed the Yellow cable from the plug that goes to the monitor at the top of the cab and presto, sorted it right out. think thats the vertical sync wire, also solved the problem with my Neo Geo and Pandora not syncing right either
you can either cut the yellow wire or release the pin from the housing so you can return it back to factory state should you wish
muddymusic said:Cut the v sync cable. With both syncs connected some stuff will give a decent picture and VERY fine control of the vertical hold but the majority of stuff won't lock properly. When you first remove the vertical sync wire it will roll like crazy but you'll then be able to adjust it to a much more stable picture.
I never use the VGA connector on these as it has always caused me problems either with a picture that is too bright or has interference/ghosting. My method is always to cut the connector off, then solder and heat shirk the rgb-gnd-sync wires directly on the jamma harness. The picture on these monitors should be lovely and solid.
The horizontal width can be controlled a bit, it appears to not do a lot when you move it, but the pot is directly in the width coil so it requires a lot more turns than the other pots to get anything to happen.
This is a massive help, thanks I'll give it a go.Brettster said:yup should work the same, tried it with my arcade vga card direct
perfect
and as mentioned via Jamma with a Pandora and Neogeo MV1C
