Donkey Kong Remix is coming!
G
Guests
Guest
DK Remix is coming to a DK near you....and looking awesome!
[tube]http://youtu.be/i1HfZeRxf_g[/tube]
A guy called 'sock master ' us getting this together over on the DKF
This is what the game is:
It's the original Donkey Kong, with the original stages, but also a bunch of new additions.
-4 Original stages
-6 Brand new stages
-3 Bonus stages (which appear after a rivets stage)
Most of the stages *also* have several variations, so when you see them the 2nd or 3rd, or sometimes even the 4th time around, they will have changed slightly.
New gameplay mechanics:
-Collapsing floors on the new rivets stages, which can crush firefoxes underneath.
-A spring on one of the new barrel stages, which can send barrels back to the top.
-Gap in the center of a new barrel stage where barrels will fall down and then either go left or right.
-Elevators on a new rivets stage.
-Hammers on a new elevators stage (and you can hammer the springs).
-The rivets+elevators stage has a switch to change the direction of the elevators.
-Blue hammers - Jumpman can *JUMP* while using a blue hammer.
New AI processing:
-Because floors can fall, firefoxes can now fall too.
-Because floors can pile up on top of each other, Jumpman can now walk *in front* of a platform - and also jump up onto it.
-Firefoxes also can jump up onto a platform..and jump back down.
-Yes, the fireballs can get to the top conveyor on the Pie stages...But, they are set not to do it often. And, they are able to come back down.
-Jumpman can fall slightly further without dying.
-Jumpman can jump without bashing his head into platforms or elevators, stopping and falling to his death.
-There is new logic for things involving situations that could/did not happen in the original game. New logic for deciding which way a barrel goes after falling down the center gap, new logic for deciding which barrel/which side the fireballs spawn from in the new conveyor stage... Um, so tricks can be learned, but they'll be different.
Expanded difficulty range:
-Some aspects of game difficulty keep increasing right up till level 22. But it ramps pretty gracefully.
-Barrel frequency slowly increases as level goes up.
-Elevators have more speeds and can get slightly faster than Classic DK.
-"Pie" frequency slowly keeps increasing as level goes up.
-Springs now do *not* hit maximum frequency on level 4! Levels 4 through 7 have spring frequency gradually increasing from old-L3 speed until hitting the old-L4 max on level 7. (I did this to balance out the difficulty.)
-selectable Normal / Hard DIP SWITCH.
-On Normal, internal difficulty does not go beyond 5.
-On Hard, internal difficulty goes up to 7. Fireballs/firefoxes eventually get even faster & spawn faster. Barrels go to 100% controllable. Barrel/Pie release rates get slightly faster than Normal. Elevators reach a higher top speed. And... there is a new type of wild barrel that can change wild mode each time it bounces (less predictable).
G
Guests
Guest
Currently in talks with a hardware guy to get plug-in boards created in order to get the new game onto DK hardware.
vib_ribbon
488CR
Hurray Banana said:
I suspected it would be needing quite a bit more rom
doesn't look like there's any/ much additional graphics, so it should just be data manipulation and changing existing variables? i guess the bonus levels would need an extra set of data though...? not too familiar with donkey kong myself so only guessing.
Dex-Jay
375CR
Nice find, looks great! Giving even more mileage to an already amazblaz game!
Thanks for posting it up Ali-fonso!
strykr
1,342CR
I'm not even a Dk fan really but this sort of thing happening in 2015 to a classic game is all kinds of awesome. Al get this guy to remix galaga while your at it
G
Guests
Guest
Now if you'd said the word ' Galaxian ' Rich, we could have been on to something!
Nintendo Arcade
AL’s Arcade
685CR
Wow this looks like a gas Al
It's getting more like playing chuckie egg with more ladders and freedom to move around more.
I like the fact you can jump with the hammer now.
Cool
G
Guests
Guest
Check out the Kill Screen on this!
Will have to get this kit when it arrives
[tube]http://youtu.be/6AKuD8gzlso[/tube]
