Euro Dig Dug restoration
2,214CR
Due to a house move I've had to put my cabs in storage so haven't been able to crack on with any of my restoration projects and I'm starting to get a bit twitchy
So instead I'm going to revisit some of my favourite restos that I haven't shown here before.
First up is my Euro Dig Dug.
2,214CR
Here are some pics I took when it first arrived. The monitor had
vertical collapse but it appeared to be running the game ok, however it
was impossible to tell if there were any pcb issues.
Cab is good
and solid, few little touch ups needed here and there. Inside is full o'
crap and it needs a thorough clean. Obviously the control panel needs
some work and a new overlay. All the metalwork is rusty and will need
stripping back & repainting.
The sound works but is distorted
so that will need looking at, and none of the coin lights or start
button lights are working. Lots to do, but should come out very nice.
The very first thing I wanted to do was get some proper feet on it,
every time I moved it you could hear it rubbing on the floor and see
little flakes of the wood left behind.
Made some room and flipped it on its back. Easy to see the problem, but at least the base is good and solid!
Broke in to my supply of new teflon feet & t-nuts.
Old feet out with the help of a lump hammer
They are well f*cked! New feet fitted, no more scraping the base and it makes the cab nice and easy to shift around now.
Monitor went off to have: A cap kit. Dry joints reflowed. Fix blown vertical output transistor. Fix blown frame IC.
Now we have a lovely crisp picture, and also can see the game is running 100%
WhiteComet has been doing some great vector work on the CPO, just a few
little bits left to tweak and it will be ready for printing
2,214CR
Got started on the cleanup.
Loom completely removed:
Power brick:
Old T-Molding removed:
ARII, this will be given a going over as it's the likely suspect for the sound problem.
Cab is now empty.
All inside areas of the cab have been cleaned up and polished.
Did the sides - First a good polish, then a rub with Novus 2, then
filled in scratches with some furniture touch-in paint, then novus 1,
and another polish.
Before:
After, almost perfect now:
Other
side had a massive scratch down the middle, there wasn't any way to
fill it perfectly but did my best. It's nowhere near as obvious in
reality and looks much better.
Gave the loom a good scrubbing
And straight out on the washing line with it!
Vector work on the CPO has been finished, thanks very much Jason
I
printed out a draft copy and made a few small adjustment for spacing
and altered the colours a little to match the what I've got left of the
original CPO.
I will be sending this off to the printers today so hopefully it will come back and fit properly!
Power brick cleaned up.
Before:
After:
Bought replacement screws, bolts & washers to replace the rusty ones.
Photo of the new CPO draft print on the actual panel, old overlay behind - it's a very good match
Had to move the pump text and start button graphics but that was it.
Thought I'd better strengthen the front base of the cab as it was
flaking a bit, so flipped it on its back again. Gave any loose areas a
good brush of pva and had to get a bit constructive with my clamps!
2,214CR
New CPO has arrived:
Hearty thanks to WhiteComet for his time spent working on the vector image - I owe you a few pints sir
It's come out superbly.
Next
to what's left of my original you can see the colours are spot on! Was
well worth spending time getting draft prints done to match it up
That arriving gave me a push to get on with prepping the metalwork for some de-rusting, and fresh paint.
New T-Molding gets fitted. Makes such a difference to a cab putting nice
new shiny stuff on, and so simple to fit as well - apart from having to
flip the cab in its back then on its side on your own of course
Start refitting the loom and pcb's. I've used all new screws and bolts for all the fixings so far.
All done, here's how it looks today. Not too shabby
Time to rebuild the coin doors.
Unfortunately there were a lot of
missing parts when the cab arrived - the switches and lamp holders were
present, as was the wiring but no mounting plates or actual reject/entry
slots, or any locks.
A rummage through my spares and I couldn't believe that I'd actually kept the exact bits needed from a cab long, long gone!
These
things are a pain in the ass to rebuild! Had to take the door off and
put it together on the floor, but now it's all in (minus mechs) and I'm
very pleased to see it back how it should be.
Metalwork has all been given a fresh coat of matt black paint and looks infinitely better.
Cleaned up, touched up and reattached the monitor shroud.
Top part refitted to cab, makes a massive difference!
Bezel given a good polish with novus and it's come out well.
Time to apply the new CPO.
Get it in to the correct position
checking the button holes line up and the edges are straight from top to
bottom. I'm happy to see it is the right size with just a few mm
overlap on either side.
Move
the clips down and cut away a section of the backing paper. Good spray
of water then apply, you can peel and stick a few times to get it
correctly positioned. Once it's right squeegee out the water.
Once
the first section is applied it's easier to do the rest. Take your time
on the curves and work a few mm at a time peeling the backing away as
you go. Last bit applied and a little bit to trim from the hinges. Move
the clips to the top and bottom areas where it's most likely to peel.
Nice new craft blade to cut out the button holes and I can stick everything back together.
Here it was when I got it:
And here it is now:
Control Panel reattached to the cab:
Cash box & service panel mounted. Think I'm about done with this one!
2,214CR
So here it is all finished, I'm really proud of this one, it's been the
most difficult resto I've done so far I think as it's needed work doing
to every part of the cab. It's come out better than I was expecting.
Big
thanks to Ross Hamilton for the cab, WhiteComet for the vector work on
the cpo, tb2000 for sorting the monitor and anyone else who gave advice
on certain bits & pieces, as always my restorations take full
advantage of the community!
Ronnie Dent
1,157CR
Ah this will be the one you robbed from me Ol
the wounds had started to heal but now it's all flooding back
Nice work, a true classic, you well deserved it
Ronnie
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Love it buddy
It gave me a laugh imagining your neighbours face when they were looking at you washing loom (did you see what I did there
Dex-Jay
375CR
A nice thorough job as usual! 2 Thumbs up! I spent many credits on a Dig-Dug back in the olden days in Dayvilles Birmingham!
Keep up the resto coolness!
frothmeister
56 (100%)
905CR
Bloody hell. I forgot you had this! That's my old cab (before Ross had it).
I really wish I'd had the resources (and skills) to get it in this shape. What a beauty....well played mate
2,214CR
Oh cool didn't know it was originally yours! It did come out very well, probably my proudest resto this one.muddymusic2014-07-25 23:07:18
Jodo
Boy is this a machine!
607CR
I forgot about this! Great work Olly. You learn so much in this hobby and pretty much any cab can be saved and made minty :) The difference between the original internal shots and the rebuild is like night and day. Damn; you've made me want to go and clean things ;) I'm sure I got a shot at this and turned you down in a moment of madness :(
2,214CR
Sadly I did have to sell it not long after finishing it so I could get my Star Wars cockpit in, but it went to someone local with a first-dibs proviso, so it will come home again if I get the chance
