Fish tales
bonehead
I'll get pix tonight
49 (100%)
1,719CR
Hi all, I am trying to fix the left slingshot on my ft pinball. I have checked the coil, transistors and wiring and all seems fine but the coil won't fire. I have done some net searching and a couple of sites mention it could be one of the U chips (74s374N).
I have a couple ordered but am unsure which location to change on the cup board. It operates coils 1 to 8'i think.
Any idea which one it could be? I have tried looking at the schematics but just don't seem to be able to understand them.
Help please!! I need to fix this for my next meet.
Cheers,
Steve
t-m
333CR
Hi Steve,
According to the manual the left sling is controlled by transistor Q76, which is in turn connected to pin 16 of the 74LS374 at U5, it does control the first 8 coils.
bonehead
49 (100%)
1,719CR
That's brilliant. Thanks for the help as I want to get this working. Once tenchipnarrives I will report back what happens.
Thanks,
Steve
t-m
333CR
If you've got a logic probe you should be able to stick it on pin 16 of U5 and check it pulls low when the left sling is supposed to trigger.
bonehead
49 (100%)
1,719CR
No it doesn't work in test. I tried piggy Back the chip but still nothing. I am going to change the transistors today to see if it makes any difference even tho when I tested them they test fine!!!
Ronnie Dent
1,129CR
That should be okay Steve but check the pin repair guide first, also you should have the voltage at the coil all the time, the driver chip provides ground so with your meter on ground and one lug of the coil you should see the 50 volts or whatever it is.
bonehead
49 (100%)
1,719CR
I have power at both sides of the coil around d 50v so will try shorting the tab on 36c to earth and see if it fires. I have spare transistors so can replace if needed. It has baffled me as everything so far checks out ok. I will report back.
bonehead
49 (100%)
1,719CR
Update.
Tried the shorting tip102 to Earth and coil fired slowly so decided to remove CPU and check further.
After testing q76 75 73 out of circuit and still testing good I decided to replace them anyway. Re fitted the pcb and powered it up, yahoo it is working so I gues even tho they teeter good they must have been flaky.
Thanks for the help a d links.
Cheers,
Steve
smarty
Ready Player One
1,290CR
Nice effort all round, glad you got is sorted Steve.
