formatting software
samusaran
248CR
I've got a 256gb pendrive which I'm trying to format to fat32 in windows but it doesn't give me the option to do this.
Is there any other software I can use?
simonden
20 (100%)
1,041CR
You just have to format in DOS if the pen drive i larger than 32GB.
Open a DOS window (Start->Run->"cmd")
type "format /FS:FAT32 F:"
(without all quotes and assumes that you pen drive is the F drive)
samusaran
248CR
its saying
format is not recognized as an internal or external command
samusaran
248CR
all sorted the link tim gave worked first time
simonden
20 (100%)
1,041CR
samusaran said:
its saying
That means that your autoexec is not set up to look in your system32 folder, all you would need to do in that case is change your directory in DOS to c:windowssystem32 but I see you are now sorted
