Fun little glitch I've discovered - Rave Racer
G
Guests
Guest
silverfox0786 said:
sorry, what was the glitch?
all i saw was you driving extremely fast and pretty good too
Keep your eye on what gear I'm in
Basically keep behind the red car and when you go over the jump before the tunnel, jump over and bounce on top of the red car and then as you do this drop the gears down to 1st and enjoy.
It takes some practice but is great fun when you achieve it. The car goes stupidly fast!
Some more video of it on my Twitch channel as i was trying to replicate it. Better quality here too:
https://www.twitch.tv/rotunda440/v/87402677
G
Guests
Guest
I was going to keep it to myself and do just that but I don't really like Rave Racer too much and also, there isn't even a score sheet on TG for Rave Racer (arcade) yet.
This doesn't work on Ridge Racer 1 or 2 I tried it on my cab earlier.
Good bit of fun though, if i were to take the time you could actually drive around the corners at that speed.
rotunda2016-09-04 16:52:37
G
Guests
Guest
I don't think you can no.
On the arcade version the heli hovers over the bridge that i do the glitch on for Rave Racer if you were to be able to go fast enough like you can on the PS version you could hit it easily but the arcade version plays a lot different and slower.
Vamino
Insert coin(s)
2,667CR
Have you tried it on proper hardware as Rave Racer emulation isn't quite perfect yet, as seen by the cars slightly dropping through the floor at the beginning of the race.
Either way, it's still an interesting glitch.
G
Guests
Guest
Actually I haven't no but i really see no reason why it won't work. I'm 99% sure it will but I guess I could be wrong.
Sadly I only have RR 1 and RR 2 boards so i can't try it here, anyone got one to give it a go? haha!
CharlieFar
51CR
That's quite bizarre. Looks fun though!
I often wonder how game glitches are discovered. Did you find this one by accident, or was there a theory behind your discovery?
