Galaxian 1980 repair
Funhouse71
988CR
Hi , bit of a novice question , when trying to get the dc voltage reading I obviously touch on the various pin A to Z with one lead. Where do I ground the other lead, on the metal casing of the cabinet or somewhere on the circuit board ??
Black probe on Ground on the circuit board will do, A or 1 / Z or 22 for easy access then Red probe to C,D,3,4 = 5vdc and then W,X,18,19 = 12vdc
qjuk
50 (98%)
1,841CR
I personally don’t think you’ve got a power issue, but it is always good to check. Going from your updated information, I’d say the most likely problem is the chip sockets on your board. Try reseating every socketed chip (ie, turn the power off, carefully remove the chip using a small flat bladed screwdriver and re-insert the chip making sure you put it back in the same orientation as it was originally- take photos if necessary). The long rectangular daughter board might need reseating as well.
big10p
Coins detected in pocket!
5,648CR
Could be PSU failure or internal fuse, then. Also, the red connector in the pic you posted of inside doesn't look like it's fully plugged in.
Hexen
487CR
This.
big10p
5,648CR
If he's correctly measuring voltages on the board and getting nothing, there's obviously a power issue somewhere along the line. Lol
Hexen
487CR
Yet a garbage screen indicates otherwise - is the meter set to AC? Being used to measuring domestic stuff, it's possible.
Or DC, and the DC converted board is being pumped with AC?...shudder! Although this would be impossible.
big10p
5,648CR
I understood that screenshot was an old one taken before it completely died.
Jukev200
11CR
I clipped one lead on A and touched the other lead with probe on the pins as indicated early, meter not showing a reading. I put it across a C type battery to check meter and read 2v dc
Funhouse71
988CR
You really need to start unclipping some of those wires and tracing back from the edge connecter to see what wire leads where. That yellow ribbon cable of 6 wires looks mainly for video so you can ignore that bunch of wiring.
It doesn't help having the +12v in yellow on 'X' pin connector with a bunch of other yellow wires. The off-white wire on the 4th pin up from 'A', letter 'D' you need to trace where that wire goes for +5v so start with that first and that will lead you to your power source for the board.
