Vics C64 question inspired wee to start writing up my experiences with old computers;
Amiga 500
ADF Sender - Serial Cable.
http://adfsender.stoeggl.com/
If you want the short cut or are missing a workbench disk a greek guy now does the kit on ebay;
http://www.ebay.co.uk/itm/AMIGA-PC-ADF-FILE-TRANSFER-KIT-EASIEST-FASTEST-CHEAPEST-WAY-TO-DO-IT-/121406417379
Amiga 600/1200
(WIP TBC.) - PCMCIA CF adaptor, IDE, CFIDE
Atari 800
SIO2SD - SD card
http://www.lotharek.pl/product.php?pid=49
http://www.ebay.co.uk/itm/Sio2sd-for-ATARI-8bit-XL-XE-/181491963697
- cheap and works well when setup correctly
BBC Micro/Master
MMC - SD Card
http://www.ebay.co.uk/itm/Acorn-BBC-Micro-B-Master-MMC-solid-state-disk-drive-/221530015661
- cheap and easy, once installed on a BBC micro you can shift break to a pre-compiled SD image of pretty much every game made for the beeb, as hosted on www.stairwaytohell.com
- some games don't work directly and have to be transferred to disk.
- no support website, ebay-only seller.
XFER - Serial Cable
http://www.g7jjf.com/bbc.htm
- simple cheap and pretty reliable, a lot better since disk transfer was added.
Omniflop - Floppy disk
http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm#OmniFlop_Overview
- can be hit or miss depending on format but has worked well, especially for the master I have that has a 3.5" floppy drive (a standard PC floppy can be used with a master once the drive selelction jumper is changed to disk 0).
Dragon 32
TBC.
grobda2014-08-26 13:48:24
Amiga 500
Amiga 600/1200
Atari 800
SIO2SD - SD card
BBC Micro/Master
MMC - SD Card
XFER - Serial Cable
Dragon 32
TBC.
