Golden Axe Bootleg Repair
dj_yt
787CR
I pulled a Golden Axe Bootleg PCB out of storage. I hadn't fired it up for 20 years or so.
Unfortunately, it didn't work. The screen was too dark, apart from when the game was performing its windowing effect, where it suddenly displayed at perfect brightness. Sometimes the screen would completely lose sync and go black.
Initially, I didn't hold out much hope. Whilst there are few customs on this boardset compared with the official Sega PCB, there are hundreds of ICs and no schematics.
Top PCB
Bottom PCB
I started by inspecting the board. There was a Fujitsu IC on the top board that was running hotter than the surface of the sun. As Fujitsus have a bad rep, I swapped it out. The new IC ran cooler, but the windowing problem persisted.
I moved around the board shorting pins with my logic probe in an attempt to figure out what area of the board was responsible for the rendering issue.
I struck gold and found an IC with a damaged leg. It was my lucky day. This was data input pin 6 of an 74LS169 chip. This is a 4-bit binary counter. It would make sense for this counter logic to be used in the windowing effect when resizing the display area. To test this theory I quickly connected the damage leg back up and the problem vanished. This was going to be an easy fix!
I socketed and replaced the IC. I powered up the board. It was now completely dead! I tried a different 74LS169 chip. Still completely dead! I wished at this point I hadn't snipped the legs of the original LS169 and had simply repaired it in-situ.
Suspecting my handiwork fitting the IC socket, I resoldered it for a second time. The board remained completely dead. I was baffled.
I then swapped in a different LS169. The board booted!
I can only presume that a combination of a faulty LS169 I had purchased and some bad soldering on my part caused the board to play dead. Unfortunately I do not have a way to test LS169s ICs out of circuit. The faulty replacement was a 74LS169BN as opposed to a 74LS169AN, but I'm assured they are compatible.
The bootleg has a number of issues, which are probably the result of it being a bootleg as opposed to a fault on the PCB itself:
- The screen momentarily fills with garbage for a frame or so on screen clear
- The sound isn't as clear as an original PCB
- There is no service mode available to test the RAMs and ROMs
dj_yt2016-02-23 19:59:02
limpy
132CR
when the screen was dark it looked to fit the screen if only shifted left slightly.
now it's working it looks like its over to the right quite a bit.
if you have not adjusted the tv there might be another issue.
Purity
The Oracle
2,999CR
I've just picked a golden axe PCB out of my faulty pile and just noticed that it is the same board as this repair lol. I can see the same logic IC's that have been changed.
Hopefully I can also repair this board
7,006CR
Nice repair , Thanks for sharing.
P.S I have one too for repair - has a few issues including freezing and restarting. I plaid it through to the end 6 months or so ago though. Allways the way though.
TheDaddy2021-04-23 18:06:23
lui01
3CR
[list type=decimal][*]
Hola, muy buen tutorial. Quisiera saber si serian tan amables de ayudarme a ver que tipo de memoria es este circuito integrado. Tengo una placa que es la misma. me falta este integrado al parecer por eso no salen los muñecos en la escena solo necesito que tipo de cicuito es se los agradecería mucho lo marco con rojo.[/list type=decimal]
