Graphics dumps
4,055CR
Is there an easy way these days to get a decent dump of the graphics from a Pacman board (mame maybe)? I want to copy them, pixel and colour perfect for something. I'm sure there was a tool years ago that could do it? And don't worry, just messing about with some code, I'm not about to rip off Namco artwork or anything daft like that.
I need either MacOS Mojave, Ubuntu 18.10 or W10 64bit compatible though, or Amiga OS 3.9, (however unlikely that is) because they are the only OS's I run now, I don't have any machines with old copies of Windows or anything like that.
bomjac
453CR
First person springing to mind is Jim Bagley given that he developed Pac-Manic-Miner and the Revival game. That would imply that he had some form of graphics editor to use.bomjac2019-04-03 03:22:10
Macro
1,984CR
F4 on mame used to bring up the various character maps and cursors cycle colours. just use a screen grab to get the image in a format you can edit.
available on many platforms ...
4,055CR
tin said:
+1 for running AmigaOS 3.9 :)
LOL!! Well, it's not either of my main OS's, but it IS the one that I want this stuff for :)
Anyway, thanks guys - been on-site with a customer all day so just catching up. Should have what I was after now ta.
Ace`
PlanB contributor #1
38 (100%)
3,831CR
Tile Layer Pro is good, it's more aimed at console roms but when it works it works very well on arcade roms too. There's also an old dos app that's even better called Turaco, it won't work on 64bit windows but it'll work through dosbox.
Hurray Banana
2,721CR
+1 always pulled the sprites and tiles from Pacman this way
4,055CR
Just cycles through the colour palette for me - I don't get the sprites. No matter though the Sprites Resource link has what I need.
Hurray Banana
2,721CR
Just uploading a quick vid martin
but keys are
F4 for decode
Enter key to toggle palette->tiles/sprites->tilemap
when in tile/sprite use left/right cursor keys to scroll through palletes
and [ ] to cycle tiles and sprites
Use - and + to change display scale (which I think is integer)
[tube]AdTEnsvDPws[/tube]
4,055CR
And I also forgot that Hurraybanana is a teacher - and today is the last day of term (at least it is here!). That's got to be worth a drink whatever way you look at it!!
Anyway, moving on.
I don't really get why mame is showing me odd colour combinations when I bring up the sprites or background characters?
I get that Pacman uses 16 colours and although it hadn't really occurred to me, I can see that those 16 can be chosen from the palette of 128 so in theory it could change the 16 colours on the fly (don't know if it actually does this or if the hardware prevents it).
So why when I view, let's say the sprites does is cycle through colours 0 through 7F and more to the point, why is the tile shown with more than one colour???!!! I can see that there is always one colour number where an entire sprite looks correct such as a fruit - is it anything to do with that?
Flinnster
The Dino King
29 (100%)
2,566CR
Yep it's just dumping -ALL- the available bitmap pixel data together with the currently selected palette. Which is why for the majority of the time you'll see total gibberish combinations.
Try it on something more complex like Metal Slug and you'll see just how insanely clever they are with tiles and palette work. Low level loveliness for pixeljunkies
For AndyC.. I'll try to find my 'DrunkenCoders' T-shirt..
Hurray Banana
2,721CR
Every tile location in Pacman can specify it's own pallete (1k of ram just for storing the palettes for each tile), the pallete is only 2 bit, 4 colours, 3 effectively for sprites as colour 00 is transparent.
Need the Easter break, pressure is immense when we get back
