Hunchback with video issues : Playpack on L-1200-1
NivagSwerdna
830CR
Socketed 1E and replaced the removed chip in socket just in case it had been a dodgy solder joint but same behaviour... will have to park this now until I get a replacement part. I have ordered "D8255AC-2" from EBay... hopefully that is compatible?
NivagSwerdna
830CR
I
Have you checked to see if the pin is high or low ? I'm sort of hoping that you did ... ;)
I put a logic probe on pin 38 and pin 37... the results were slightly weird... pin 38 appears HI and pulled low with a Button press but does not flow through the PIA, pin 37 seems to be pulsing or at least have a lot of noise rather than being hi or lo. Something weird.
NivagSwerdna
830CR
is it pulsing with 8255 removed ? (i.e. is that the cause)
Just tried... with 1E removed.... Logic probe shows HI on pin 38 and pin 37 unless the appropriate button is pressed in which case that pin is pulled LO; no noisy pulsing.
The i8255 is a bi-directional device so maybe mine has decided that one of those pins is an output; in any case I'm pretty sure it is misbehaving.
Will be a few days before I get a replacement.
NivagSwerdna
830CR
i8255 arrived, so fitted...
Title screen is back in action. Funny that... I think that must have been broken since before I bought it.
Still need to sort out the incorrectly burnt colour PROM...
NivagSwerdna
830CR
Burnt a new colour PROM...
using the 6e_prom.bin image from hunchbks.zip
Doesn't seem to look quite like MAME... weird. I think I am probably done though... everything seems to work.
Now the $1M question... should I convert it to Super Cobra and then on to a phillmurr multigame?
Macro
1,995CR
Looked better with the original prom :)
Get phil to add it to his multigame, I put an S2650 based game in my galaxian one. (mind you, that was a one time only)
NivagSwerdna
830CR
Decided that I didn't really like hunchback!
A set of ROMs, a PROM and a Z80 and we are back to Scramble...
I'll keep the Hunchback PlayPack, ROM set and PROM just in case... just an easy swap.
RolyRetro
277CR
I read that Hunchback was originally meant to be based on Robin Hood, hence the soldiers and the castle ramparts rather than a cathedral setting. But Robin Hood came out a bit lumpy and they decided to call it Hunchback instead! Not sure if this is really true but the graphics do support this. So it’s not Esmerelda but Maid Marion being rescued?
I played this a lot on the Spectrum, reminded me a lot of Pitfall.
