Identifying PCB revision
big10p
Coins detected in pocket!
5,635CR
I'm thinking of doing a HSS patch mod to my Time Pilot '84 and need to identify which revision I have, to apply the correct patch.
The screen printed text just above the edge connector has (B) in it, so I'm guessing it's revision B?
The board only has mask ROMs so wasn't sure what to set my EPROM programmer to in order to dump one for romident. Looks like they're 8k ROMs? Can I read them by simply specifying a generic 2764?
Thanks.
NivagSwerdna
744CR
Ah I see
Looking at the Time Pilot 84 schematic I can see that either 2764 are populated or half the number of 27128 and the jumper JP3/JP4 is moved.
I guess you have the 27128 flavour; differs at pin 26.
As for Rev B... No ideal what that refers to.. GX388 is Time Pilot 84 and the later GX393 would be Time Pilot.
Read them as 27128 and see what happens; harmless to a 2764.
big10p
5,635CR
Ah I see
Ok, I'll try reading one as a 27128. Just didn't want to accidentally damage one.
Arcade ROM Patcher has patches for 4 different versions. Just trying to identify which one applies to my board.
NivagSwerdna
744CR
Well I'm a bit disappointed by that...
and
I thought that looked like a sure thing.
and would hope to end up with...
ROM_START( tp84b ) ROM_REGION( 0x10000, "cpu1", ROMREGION_ERASE00 ) // 0x6000 - 0x7fff space for diagnostic ROM ROM_LOAD( "388j05.8j", 0x8000, 0x4000, CRC(a59e2fda) SHA1(7d776d5d3fcfbe81d42580cfe93614dc4618a440) ) ROM_LOAD( "388j07.10j", 0xc000, 0x4000, CRC(d25d18e6) SHA1(043f515cc66f6af004be81d6a6b5a92b553107ff) ) ROM_REGION( 0x10000, "sub", 0 ) ROM_LOAD( "388j08.10d", 0xe000, 0x2000, CRC(2aea6b42) SHA1(58c3b4852f22a766f440b98904b73c00a31eae01) ) ROM_REGION( 0x4000, "audiocpu", ROMREGION_ERASE00 ) ROM_LOAD( "388j13.6a", 0x0000, 0x2000, CRC(c44414da) SHA1(981289f5bdf7dc1348f4ca547ac933ef503b6588) ) ROM_REGION( 0x4000, "tiles", 0 ) ROM_LOAD( "388j02.2j", 0x0000, 0x4000, CRC(e1225f53) SHA1(59d07dc4faafc82999e9716f0bba1cb7350c03e3) ) ROM_REGION( 0x8000, "sprites", 0 ) ROM_LOAD( "388j09.12a", 0x0000, 0x4000, CRC(aec90936) SHA1(3420c24bbedb140cb20fdaf51acbe9493830b64a) ) ROM_LOAD( "388j11.14a", 0x4000, 0x4000, CRC(29257f03) SHA1(ebbb980bd226e8ada7e517e92487a32bfbc82f91) ) ROM_REGION( 0x0500, "proms", 0 ) ROM_LOAD( "388j14.2c", 0x0000, 0x0100, CRC(d737eaba) SHA1(e39026f87f5b995cf4a38b5d3d3fee7561762ae6) ) // palette red component ROM_LOAD( "388j15.2d", 0x0100, 0x0100, CRC(2f6a9a2a) SHA1(f09d8b92c7f9bf046cdd815c5282d0510e61b6e0) ) // palette green component ROM_LOAD( "388j16.1e", 0x0200, 0x0100, CRC(2e21329b) SHA1(9ba8af294dbd6f3a5d039c74a56e0605a913c037) ) // palette blue component ROM_LOAD( "388j18.1f", 0x0300, 0x0100, CRC(61d2d398) SHA1(3f74ad733b07b6a31cf9d4956d171eb9253dd6bf) ) // char lookup table ROM_LOAD( "388j17.16c", 0x0400, 0x0100, CRC(13c4e198) SHA1(42ab23206be99e840bd9c52cefa175c12fac8e5b) ) // sprite lookup table ROM_END
i.e.
big10p
5,635CR
and
i.e.
Problem solved! Turns out I needed to uncheck a Pin Detect box in my reader software, as well as the ID check.
Turns out mine is indeed revision B. Tp84b (set 3) in MAME.
Thanks!
