Ipac2 and hyperspin
Pharo
259CR
Hi
I've ran into a bit of of problem trying to get this set up in my cab.
I've had an old pc in my cab running mame and loads of emulators for the last 5 years without problem all controls running through the ipac2, decided it was a bit dated and I was missing out on a lot of new stuff so bought a faster pc with hyperspin and all the emulators already configured it came with a gamepad and xpadder installed everything plays great as long as you use a game pad but I want to play it in my cab with my ipac and controls.
So the question is what do I need to look into to get this working.
Thanks in advance Brian.
Pharo
259CR
Hi thanks for the reply so does that mean I have to remove xpadder as I think that's the default set up and start from scratch to suit the ipac.
ZedEx48K
8-Bit
1,414CR
Xxpadder is just there to add extra shift functions, and will only work when the correct controller it is defined to is hooked up, but you can just disable the start with windows part of it.
Pharo
259CR
Hi thanks for the reply how would I configure the controls outside hyperspin.ive checked the ipac it's recognising what I press when in notepad so it works okay.
Cheers Brian
ZedEx48K
8-Bit
1,414CR
As I said, you need to find where the emulators themselves are kept on the HDD, then run them one by one redefining the controls and saving/quitting.
To add, you may well have problems with some of them if using the default pac device mame keys layout, since alt etc are used.
ZedEx48K2019-12-18 17:13:56
