Jamma harness ground connections?
kingtreelo
17 (100%)
1,491CR
Hi, so i need to tie all my ground connections together on my jamma harness and other than running a little wire, is there an easier way to do this?
I would guess there is a connector that you can put one ground wire in that bridges the 2/4 pins?
Does something like that exist, and if so, what is it called?
4,982CR
The idea really is to have separate cables back to the PSU for every ground pin, and in the same way have separate cables for every 5V, 12V and -5V pin.
This reduces the voltage drop across the cables.
Otherwise you risk different voltages being applied to different games, depending on their power draw, unless you're going to twiddle the PSU dial every time.
favouredson
Super Star
1,253CR
As JB stated, the more the merrier.
If your cabinet loom is properly wired it will also make up for deficiencies in any JAMMA adaptors you might use.
kingtreelo
17 (100%)
1,491CR
so ive had a look today and cant see any spare wires at all to hook up to the harness, i was expecting to see a few ground wires on the loom that were loose but nothing...
any ideas?
favouredson
Super Star
1,253CR
Ideally, you would add wires from the PSU to the connector.
If you are unable/unwilling to do this then you could always do a bodge and make up a JAMMA to JAMMA adaptor with all the ground pins interconnected.
kingtreelo
17 (100%)
1,491CR
could i not just connect the grounds that are already wired to the other pins?
im not even 100% this is going to fix my problem but its worth a shot
