Jamma to lcd vga monitor
Pharo
203CR
Hi all picked up a cab last night,it has one of those Chinese jamma looms in it playing a 19-1 board and an LCD monitor in it which isn't great news so the question is what can I do to get to play my jamma boards in it as obviously no VGA connection on the boards,ive have another cab with a crt in it to play these boards but would like to have two running together.
Apart from the LCD screen it's a cracking wee cab.
Cheers Brian
TheDaddy
14 (93%)
7,087CR
Second what big10p says.
You can wire jamma to vga i think , if i remember i will have a look tomoz.
Edit : its scart you can wire , for vga its the rgb to vga converter , gnobes i think.
Dave.
Pharo
203CR
Cheers for the replies I think I might just leave it how it is as big 10p says I wouldn't trust plugging my boards into one of these jamma looms,I've got a spare 60-1 board so might put that in instead or might just keep it playing super mario.
Venom
747CR
I'd just whack a little SFF in it with a J-pac, I'm quite pleased with my set up. Yes it needs an little sound amp and time to set up.
Pharo
203CR
I might do that Darren but the thing is the control panel only has 2 buttons per player it did only have 1 button originally and another has been added at a later date not very well I may add and I don't think it would look right with more buttons as it would waste the Mario control panel overlay.
Georgian2
1,813CR
Is this one of that cabs from Hungary? There is one guy there selling these. Looks good. Dose it have space to put an crt inside?
Mc-Q
1,450CR
you can run jamma boards on VGA with a £20-30 GBS8220 from Sintech and a resister divider on the sync line.
make sure you put the resistors or the jamma sync voltages can slowly damage the adapter.
the jamma sync is upto 5v and the GBS8220 has a max input of 3.3v
Pharo
203CR
Don't know if it came from Hungary but it is a full size cab plenty of room for a crt, have you got a link to the one in Hungary and I will compare it.
Pharo
203CR
Thanks for the info but that might be out with my capabilities as I'm guaranteed to do something wrong 😄,as big 10p says it might be a risk plugging a board into one of those crappy Chinese jamma looms.
Pharo
203CR
TheDaddy
14 (93%)
7,087CR
If i was closer I would come and do wiring and sort it for you. Not that hard to do if you dont mind getting your hands dirty, Not much you can get wrong to be fair. As you said though using a multi in there would be fine. Issue with cheap cables are the power consumption , they are not thick enough to take the ' Umph '.
Nice looking cab though,
Dave.
Pharo
203CR
🤣my mate with the printing business is still on the case he's not sure what to do with the control panel yet and as my cab is a midi leisure 2000 there is no marquee and also the print on the glass so he wants time to think about it.
Pharo
203CR
Yeh will need shrinking and re positioning ?? I assume anyways.
You got pics of it ??
Dave.
Here's some pics of the cab I'm going to use for it.
