Kieser conversion project
7,359CR
Yeah, you’ve done basically the only thing you can to accommodate 6 buttons in that panel.
Same with the monitor - it’s such a tight area!
I ended up using scalers and vga panel monitors as per the Namco refurbs.
It’s not ideal but it works, 31hz running natively for the Naomi and an irken scaler for the MVS.
I have two old PC crt’s that will work for the next two - I have two compaq monitors capable of low res images via VGA so I’m feeling confident about them dropping in but I’ve not looked at the monitor frames yet
And again, if you have those fins - I WANT THEM! Hah
I think I have them fins for you..
Yeh monitor is tight!
Nice cabs once you have figured out the panel .. enough games for four buttons to keep you happy for ever😎
7,359CR
Wosh —- 2 year pause ..
Been busy with work ..
Now had a week spare so i returned to this project ..
Yesterday it came in from the shed for the first time into its rightfull place inside to be played :)
ISO 240-115
Hantarex mtc900/e to a tube i saved from the land fill recycle center ..
Drilled the 24mm start buttons out today ..
And wired up p1 had a few games .. 😊 chuffed this is now going how id dreamed it up in my Head ..
Next jobs to do ..
Sound amp
Marquee light / top marque
Sort Player 2 .
7,359CR
Are you not using the original plastic monitor bezel at all now then?
If not I’ll take it off you if you still have it?
Still unsure what I’m doing
With the surround for my cab yet
Toying around with bronzed Perspex
I will get the parts together bud
I got the lion head also
