Lady Bug High Score Save Patch
GadgetFreak
952CR
The easiest boards for this patch are the later Universal single boards (8106-II) or the bootlegs which seem to be copies of this board as you will just need to replace the 6116 at 2NP (next to the 2 sprite roms) with an NV version such as DS1220, M48Z02, U63716DC etc.
If you have a Universal twin board version it may still be possible, in theory you would need to replace the 2114's at L3 (D0-D3), M3 (D4-D7), N3 (D0-D3) & P3 (D4-D7) with a 6116 NV equivalent as I don't think an NV version of the 2114 exists. You could just replace the ones at N3 & P3 as long as you tie off the upper adress line of the 6116. I don't have access to a twin board version so if you try this please reply with how you get on.
** UPDATE - Forgot to mention this **
To reset the high score table hold down 1 & 2 player start buttons when powering the board up.
As with all my High Score Patches, please post a reply or click thanks if you find this patch works for you.
l1.c4 or lb1a.cpu or lb1b.cpu
Code:
[b]02E0: change these bytes  0A 03  to  20 5F[/b]
l6.k4 or lb6a.cpu or lb6b.cpu
Code:
[b]0397: change these bytes  52 5D  to  76 5F[/b]
[b]
[/b]
[b]0807: change this byte  10  to  0F[/b]
[b]
[/b]
[b]081F: change this byte  10  to  0F[/b]
[b]
[/b]
[b]These bytes should all be FF before you changes them.[/b]
[b]0F20: CD 0A 03 3A 00 90 E6 60 20 03 CD 54 5F 11 7C 5F[/b]
[b]0F30: 21 60 6F 06 10 1A BE 20 1B 13 23 10 F8 21 70 6F[/b]
[b]0F40: 11 73 60 01 1B 00 ED B0 21 90 6F 11 80 D3 01 6D[/b]
[b]0F50: 00 ED B0 C9 21 7C 5F 11 60 6F 01 10 00 ED B0 21[/b]
[b]0F60: 73 60 11 70 6F 01 1B 00 ED B0 21 80 D3 11 90 6F[/b]
[b]0F70: 01 6D 00 ED B0 C9 CD 52 5D C3 5F 5F 47 41 44 47[/b]
[b]0F80: 45 54 46 52 45 41 4B 32 30 31 37 DE[/b]
Note: If your board is like mine and has 2764 roms for the code you will find that rom1 is l1.c4+l2.d4 and rom3 is l5.j4+l6.k4 so you will have to add $1000 to the offsets for l6.k4
GadgetFreak2017-04-03 00:46:39
Hurray Banana
2,721CR
Added to sticky
Ronnie Dent
1,171CR
Would this work for universal space panic? single board apart from the small sound board?
Code:
Space Panic                   Oct,1980   Z80  #8015
Thanks Ronnie
Ronnie Dent2017-04-02 10:12:28
GadgetFreak
952CR
The patch is specific to Lady Bug's memory layout and code. I could probably do one for Space Panic but replacing some of the ram would be more difficult as it does not use 24 pin 6116 type static ram.
virtvic
The Cabaret King
21 (96%)
1,977CR
Has someone done this and can upload the rom?, so I can burn it for my wall mount Ladybug.
I have no clue how to edit sexy hex or whatever it's called...
GadgetFreak
952CR
Most Eprom Programming software have a buffer editing option which allows you to edit the hexadecimal bytes in the eprom. Typing my patches in though is a bit 80's. I am finishing off a patching program but I'm not completely happy with it yet. PM Sent.
virtvic
The Cabaret King
21 (96%)
1,977CR
Gadgetfreak kindly edited my roms for me and I burnt them tonight and installed a Dallas chip in place of a 6116 ram and the mod worked like a charm!
I now have FREEPLAY which cycles thru attract mode and my Hi Scores are now saved, with names / initials.
EXCELLENT WORK, GADGETFREAK!!!
