To start looking for the missing sprites i went straight to the sprite roms which are located on the cpu pcb L7/M7.Scoped the address and data pins which were all inactive🫥 ,scoped the OE pin on both roms which was stuck high.These OE pins should be toggling.The OE pins goto to B6(ls174) pin 12,scoped all output pins but all high,checked pin 9 for a clock signal
but got zilch.
This clock signal goes to H5(ls42) pin 6 output pin,pin 12 and 13 was active but nothing on pin 14 and 15.Looked at J5(ls393) pin 1 for a clock but zilch followed to E7(ls175) pin 10 and nothing,pin 3 and 7 was active.There was a good clock signal on pin 9 and pin 4 and 5 had data inputs,took out this ls175 and replaced with a new one.
Powered on and to my amazement.............................................................................
LADY BUG LIVES
,played this for an hour and what a fantastic game,very challenging and addictive.Interesting is this boardset is identical to snap jack and cosmic avenger and i read someware that to do a conversion its a matter of programming the roms and bipolar proms.I have ordered some proms and 2732 eproms to do a conversion to cosmic avenger,never played it but would like to play it on the real hardware.
I might sell this boardset with the cosmic avenger roms fitted and together with its ladybug rom set.
but got zilch.
LADY BUG LIVES I might sell this boardset with the cosmic avenger roms fitted and together with its ladybug rom set.
